I've got a new little project going on. I'll only be updating it
HERE
I've had my Exotek for a while and I have not really focussed on it but I have decided to give it some attention as I have realised how much I love driving this car! :good:
It's fast and very robust! It sticks to the ground like nothing I have seen before and jumps like a loon!
At the same time I have decided to build up a second one to better on some of the mistakes on the first one and to have a spare 'just in case'
I started the first build with a Team Associated FT RC18B kit, an Exotec conversion and some bits and pieces.
Alloy diffs
Alloy outdrives
Alloy hub carriers front and rear
Alloy c-hubs
carbide diff balls
some titanium screws
parts from the FT RC18B kit
AE shocks
Gecko 30shore front foams all round trued to 57mm.
Wraith 7K motor
Quark 33A ESC
Spektrum micro receiver
Yeah Racing 900mah 20c lipo's in saddle pack configuration (so 1800mah in total)
I've had to make zero modifications apart from those mentioned in the Exotek build manual to make it all fit and it fits absolutely perfectly!
Car setup:
Front
80W oil + Gold springs
3mm travel limiter in shocks (nitro fuel tube cut)
Toe +1 deg
Camber -1 deg
Rear
30W oil + blue springs
Camber -1 deg
Ride height: bones just below level
Issues so far:
1. I've bent 4 x GPM titanium CVD's so we are back to the original dogbones for the time being. More CVD's on order!
2. The alloy outdrives must have the collars installed otherwise they just bend open
The second car will have titanium outdrives and MIP CVD's fitted straight away and will run with a Tekin Mini Rage ESC to start with.
BTW - the second car is running the prototype Atomic Carbon shock towers.
You might notice on the new car that I am running AE rear shocks on the front in the outside mounting hole and that all 4 shocks have Driven productions spring retainer caps on.
The first car is using a Hitec HS-65HB servo with stock but modified servo saver. The second car is using a Hitec HS-82MG with Xray M18 servo saver. I've had to modify the M18 servo saver to clear the steering linkage and because it's much wider I've had to stick it down (and only used 1 side of the servo mount). I've also had to cut the inside tab off to clear the drive shaft.
In the new car I might experiment with running just 1 lipo and dropping the elctronics to the chassis with a counter weight. As soon as I get the CVD's I'll start putting the car together and post some more pics.
I also still need to source a Tekin ESC! It shouldn't be this hard!
