Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-24-2007, 07:49 PM   #1
Cain's Avatar
Trader Rating: 34 (100%+)
Default Tekin Rage 6.8 unit, no punch?
I just got in a tekin unit, and I am thinking my batteries are suspect, but right now it has like no punch under load in my vehicle. I have played with the various settings, and when the vehicle is not on the ground, seems fine, under load however nothing.
This is not a slipping diff issue either, checked the diffs and they are fine.
Any ideas?
Academy GV2 Pro 1/10 Scale Brushless Buggy
Academy STR4 Pro II 1/10 Scale Brushless Sedan
Ofna Hyper 9E 1/8 Scale Brushless Buggy
Old 10-24-2007, 08:30 PM   #2
Bermbuster's Avatar
Any ideas?
what vehicle and what is your gearing?
what batteries are you currrently using....
and at what amperage are you charging them...(2 amps is a good number)
Bermbuster is offline   Reply With Quote
Old 10-24-2007, 08:38 PM   #3
Trader Rating: 23 (100%+)
Cain,
Make sure you are running the 60 tooth spur gear and 10 tooth pinion gear, that would make my RC18T scoot nicely with the 6.8 motor.
Rc guy is offline   Reply With Quote
Old 10-24-2007, 08:49 PM   #4
wes95_z28's Avatar
Also make sure you have changed your battery connectors to deans or some other kind of high current connector. The stock mini connector just can not handle the high amp flow brushless motors pull. You should notice a great increase by just changing this. other than that your battery probably isnt up to the task, you need damn good battery to run the brushless systems, thats why lipo is so popular.
Wes
Kyosho 777 WC w/ big bores, RB S5, ACE 1313 s., Air 357 t., JP-3
HPI Savage X SS, Axial .28, Hitec 5645 Steering servo
Nitro TC3, O.S. .18 CV-R
Associated RC18T, Brushless, Lipo
wes95_z28 is offline   Reply With Quote
Old 10-25-2007, 07:08 AM   #5
Cain's Avatar
Hello everyone.
This is in an RC18T.
Right now the only mini batteries I have in are some stock Associated 6 cell Nimhs, the ones that come with the RTR kits. Connectors are all deans, I also changed them over to 12 guage wire and even put 2 packs in series. it bumped up the no load speed alot, but under load, still needed to wind up. Packs those may be garbage.
I do have a 14.8V 4S lipo that I am going to see about hooking up to just check the pull of the vehicle. Its for my 1/8 scale buggy, so of course not going to drag it around, just hook it up to see if it will pull when under load. Will this cause any issues? I don't think it will, but want to make sure.
I will also check the gearing too.
So basically if the batteries aren't up to it, the acceleration will suffer?
I am looking into some lipos for it or some elite 1500 packs, what would you guys recommend and would it be better to do 3S or 2S? I want this to be controllable at the track, so I was figuring 2S, but I do want some good punch. I also need to be able to use NiMHs as well at the track.
Old 10-25-2007, 04:59 PM   #6
Bermbuster's Avatar
Hello everyone.
you want to get some 20c lipos....apogee magnum limn packs will do the trick....a 2 cell lipo will make the truck fast...a 3cell lipo will make it stupid fast....as far as nimh you want ib1400s or elite 1500s....
Forum Jump
Tekin mini rage 6.8kv & esc sparkplug1288j R/C Items: Wanted to Buy 5 08-29-2008 10:32 AM
Tekin Q&A for B1 and Mini Rage! Randy_Pike Micro and Mini Scales 13 06-10-2008 07:51 PM
FS: Tekin mini rage esc and tekin 6800kv! 1/18th! tt01-demon Australia For Sale/Trade 7 05-24-2007 01:59 AM
Need ESC for Tekin Rage 6.8 sfenn914 R/C Items: Wanted to Buy 0 05-12-2007 10:01 AM
Tekin Mini Rage w Tekin 5.4k motor senna555 R/C Items: For Sale/Trade 0 12-26-2006 06:02 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
