Originally Posted by tedd69
Thanks, what about discharge rate 10c, 15c, 20c. What does it mean?
the C means capacity. a 10c 1000mah pack can discharge 10x its capacity.
1000mah=1amp 10c x 1= 10amps....
technically a higher mah pack will also discharge more amperage as well.
Try to match your discharge rate to your speedo.....
mamba 25
10c 1500mah pack =15amps
15c 1500mah pack =22.5 amps
20c 1500mah pack= 30 amps
hope this helps....
