Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 09-16-2007, 02:35 PM   #1
TC_Tuner's Avatar
Trader Rating: 23 (100%+)
Default MIP ball diff in MiniT install question
I need to confirm what direction the MIP ball diff gets installed into a Mini T.
From image in the instruction sheet, I have this built right. Looking at the 'ridge' on the diff gear, this gear can really only go in one way, but that puts the adjustment for the diff on the left hand side of the truck. From everything that I know, this will allow the diff to loosen itself quickly.
First, am I correct that the diff adjustment should end up on the right hand side of the truck?
Assuming this is the case, did you have to build the diff different from the image in the MIP instruction sheet?
thanks in advance-
TC_Tuner
Airtronics | Byron's Fuel | Pro-Line | OS | Kyosho | Ballistic Batteries | Al's Hobby Shop
MRX4-X MRX4-R F180 Inferno GT VOneRRR Evo WC TE Yokomo BD FM1e Recoil M18 Pro Scalpel
Baja 5b SS 5T HB D8 E-D8 ERevo Turmoil Pro GT2 T4 Slash HB Cyclone D4 Schumacher CAT SX Mini ERevo Vendetta ST Mini T Micro T
TC_Tuner is offline   Reply With Quote
Old 09-17-2007, 05:05 PM   #2
TC_Tuner's Avatar
Am I correct that the diff adjustment should end up on the right hand side of the truck?
I know I'm not the only one with a MIP ball diff in a Mini T... Can someone confirm what side they have the allen adjustment side on theirs?
thanks-
Eric
Old 09-20-2007, 04:21 PM   #3
hobbipro's Avatar
I dont have the MIP ball diff, but did go with the original losi one thats prebuilt. Atleast for the losi diff, the adjusting screw will go to the left of the tranny. Makes it pretty easy to get to.
*TA05 IFS-R* F103RM* E-Revo* SC8E* Baja 5B SS* FTRC10B4* SC10*
hobbipro is offline   Reply With Quote
Forum Jump
MBX5R Diff Install Help!!! newbie2006 Nitro Off-Road 5 06-22-2007 12:36 PM
Tool to install Ball Bearing ScanneR Nitro On-Road 3 03-27-2006 06:28 AM
trouble with the pivot ball install on my ntc3 indy_rc Nitro On-Road 3 03-24-2006 01:24 PM
carbide ball diff question Kasey Electric On-Road 7 01-23-2005 07:56 AM
Ball Diff Question???? Steevo Electric On-Road 4 10-30-2002 10:39 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
