Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 09-15-2007, 09:20 AM   #1
Default RC18B RTR VS mini Inferno
Hi.
Help me and my freind to decide which car to get
the mini iferno or the RC18B
we dont care about the Size.
We Just Wanna know which is worth and which one we can upgrade more!
Plz Help
Bar and Ben.
Potter is offline   Reply With Quote
Old 09-15-2007, 02:31 PM   #2
Bermbuster's Avatar
Originally Posted by Potter View Post
Hi.
Plz Help
Bar and Ben.
If you are into buggies you should give the vendetta a look as well.
The Mini Inferno out of the box needs bearings, shocks, steering knuckles.
It will only go about 18mph stock. It uses saddlepacks. You will spend a lot of money to make it go fast....
The RC18B needs the steering tightened up (DP draglink $6) and a gear cover (DP $12) It goes over 20mph stock and the aftermarket makes a lot of hop ups...It uses standard battery packs and you can make it go very fast .....
the vendetta out of the box needs nothing. THe front end is a little weak but can be hopped up....
have fun choosing.....
remember there is no perfect vehicle..I suggest the rc18b based on support available hop ups and ease of use....we personally have 4 rc18 's
Bermbuster is offline   Reply With Quote
Old 09-16-2007, 05:18 AM   #3
Who is We?
ok
the mini inferno is down !:P
The RC818B is better beacause the supporting parts...?
you have msn?
the vendetta is suck i saaw it once.....
mabye i wrong....
Old 09-16-2007, 06:18 AM   #4
Bermbuster's Avatar
Who is We?
ok
you have msn?
mabye i wrong....
We is me and my son.
The RC18B is a great platform. You can also switch it from a buggy to a stadium truck to a monster truck and to a rally car with a few parts(rally needs the most). The stock electrics are good/better than most rtr s
You can go brushless on this sized vehicle for $100 or less....
You can even use a 9000kv motor in them....insanely stupid fast......
Another good thing about the RC18 is parts are not expensive.....
and they are easily found....now you need to decide who gets the red/white/blue one and who gets the black/orange/white one.....
Old 09-16-2007, 08:47 AM   #5
MADMAN23's Avatar
Trader Rating: 6 (88%+)
Send a message via AIM to MADMAN23
well the vendetta is very good.. i have 5 of them... and i got the 18b did't use it yet... and i had the half 8 you are going to put more $$$ into that then the rest...
catch me if you can....
WWW.RCFANATICS.NET
http://rcraracing.com/sitebuilder/images/FORUM/index.php
C&D R/C RACEWAY
Team Wicked Racing
MADMAN23 is offline   Reply With Quote
Old 09-16-2007, 08:57 AM   #6
so you suggest to get the vendetta or the rc18?
Old 09-18-2007, 02:06 AM   #7
I have both cars and they are both great!
The Inferno is slightly bigger and heavier and will handle rough tracks better. It is infinitely upgradeable but as been said before you will need to upgrade quite a bit of the car to make it handle brushless performance. I had to replace the entire drive train with metal gears, outdrives, locked the centre shaft, etc. but now it flies and I love it! It's still is my favourite micro car of all time.
The RC18B will be a much faster micro racer against other micro's for cheaper as you really don't need to do too much to it. It's also very upgradeable but for racing most of the upgrades really aren't needed.
So in short, if you are more of a basher then get the Inferno and if you are a serious micro racer then the RC18 is a better buy.
frogger is offline   Reply With Quote
Old 09-18-2007, 02:55 AM   #8
JeromeB's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to JeromeB
What packs are you running in the Exotek? Im trying to find a 2cell saddle lipo, otherwise its the 2cell sitting in one of the rear corners.
JeromeB is offline   Reply With Quote
Old 09-18-2007, 03:36 AM   #9
They are Yeah Racing 900mah 7.4v packs.
Just do a Google for: Yeah Racing (#LP-0015) Li-Po 7.4V 900mAh 2S1P Battery (SR)
They were $14.50 each, I ordered 4 and made 2 saddle packs. You need to squeeze them in a little but they do fit without modification.
Old 09-18-2007, 04:07 AM   #10
JeromeB's Avatar
Does that make a 900mah 14.8v pack or an 1800mah 7.4v pack?
How are you going to hardwire them? Are they the best packs to do it with?
Old 09-18-2007, 04:20 AM   #11
You can do either but I did 1800mah 7.4v packs
Old 09-18-2007, 04:42 AM   #12
JeromeB's Avatar
But when you connect the 2 packs together, does it add voltage or capacity together? Or both?
Old 09-18-2007, 05:53 AM   #13
MADMAN23's Avatar
vendetta .... i raced it yesterday ( all day and night...) aganst the 1/10 scale and it was going faster then they were lol... and only broke a front hub..
WWW.RCFANATICS.NET
C&D R/C RACEWAY
Team Wicked Racing
Old 09-18-2007, 12:23 PM   #14
If you connect them in series then you add the voltage together, not the capacity.
If you connect them in parallel then you add the capacity together, not the voltage.
Old 09-18-2007, 01:50 PM   #15
JeromeB's Avatar
How would I connect them in parralel?
Forum Jump
Mini Inferno Buggy converted to Mini Inferno ST nozauta619 Micro and Mini Scales 5 11-13-2007 01:03 PM
WTT Mini Inferno RC18B RC18T YokomoMR4BX R/C Items: Wanted to Buy 16 05-04-2007 10:32 AM
Mini Inferno 09 Engines and RC18B RC18T YokomoMR4BX R/C Items: For Sale/Trade 11 03-27-2007 09:54 AM
Largest Kyosho Mini Inferno/half 8 sale all with brushless 2 infernos, 1 inferno ST nobike R/C Items: For Sale/Trade 114 03-27-2007 09:00 AM
KM Concept Mini Inferno/Inferno ST Graphite Conversion kit (blue) SpeedTech Micro and Mini Scales 5 09-06-2006 08:02 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
