RC TT-Gear Buggy Champ - GB02 (Finished)
Anyone seen this? It looks cool. OLD school rough rider shrunk down 1/16th scale. 179.95 @ tower. 149.95 @ ULTIMATE HOBBIES plus free shipping. Lots of hopups @ THE TOYZ. I have one coming will report soon. Here is a YOU TUBE VIDEO. Gonna be a good project for brushless and lipos
http://www.youtube.com/watch?v=5y7ZCs9w5Mk
This is the electric powered, radio controlled, ready to run, 1/12 scale
Tamiya TamTech-Gear Buggy Champ Off-Road Buggy.
FEATURES: Chassis: GB-02 Drive: Two wheel rear drive with universal drive shafts Motor: 370 size Battery: 6-cell flat 7.2V 1100mAh NiMH, 2/3A size cells with white 2-pin female connector Battery Charger: 120V AC wall type with red 2 pin male connector Radio: Tamiya Expec SP TTU-03 27MHz AM pistol grip transmitter with steering and throttle trim and reverse and TSU-02 steering servo, transmitter does not have charge jack ESC: Tamiya TamTech-Gear ESC with forward and reverse (TAMC1383) Shocks: Four plastic bodied, friction (not oil filled) Suspension: Double wishbone front and rear Wheels: Five-spoke Tires: 2.36" (60mm) wide, .86" (22mm) diameter Spur Gear: 64 tooth Pinion: 16 tooth Caster: Adjustable, caster/toe-in refers to the angle of the front suspension when viewed from the side of the car in relation to the chassis Camber: Non-adjustable Body: Constructed of polycarbonate with decals applied Transmission: Ball differential with full ball bearings and adjustable slipper clutch
INCLUDES: Tamiya TamTech-Gear Buggy Champ, 370 motor, 64 tooth spur gear, 16 tooth pinion gear, instruction manual, Tamiya Expec SP 2 channel AM radio, electronic speed control, receiver, servo battery and charger
REQUIRES: Radio Batteries: 8 AA for transmitter Charging battery for 5 hours before use
SPECS: Overall Length: (278mm) Overall Width: 7.24" (184mm) Overall Height: 3.5" (89mm) Wheelbase: 6.96" (177mm) BODY- Length: 10" (254mm) Width: 3.75" (95.25mm)
