Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-02-2009, 04:21 AM   #121
Send a message via AIM to todb
I need some help on a servo saver. I run a Hitec HS 82 MG in my M18T pro and the stock servo saver doesn't like to center. Any ideas? This servo is almost new, as i rarelty play with truck. It just did not like to center which I don't like. I tried the search function as well and it would not work for me, it always said no results. Thanks for any help.
todb is offline   Reply With Quote
Old 07-02-2009, 07:58 AM   #122
ttppll's Avatar
Send a message via AIM to ttppll
Are you using both of the servo saver springs or just one? If you use both you should not have a problem and maybe it is a servo issue.
Tom L.
ttppll is offline   Reply With Quote
Old 07-02-2009, 05:51 PM   #123
i built it like the instructions said to do it. I will though to make sure.
Old 07-03-2009, 03:06 AM   #124
it is the servo, it won't center. so i need another one. Any ideas on a good one not named Hitec. Thanks. I tried the search function again but i am getting no response when i searched for " servo" or "micro servo". Once again thanks
Old 07-03-2009, 05:23 AM   #125
ttppll's Avatar
The Multiplex Mini Polo Digi 4 is very good.
Tom L.
Old 07-03-2009, 03:00 PM   #126
Suspended
Trader Rating: 10 (92%+)
I just got one of these on Ebay today, I didnt even expect to win it with a $50 bid, but I did!!!!
Cant wait to start racing it now.....
crpt_racer is offline   Reply With Quote
Old 07-03-2009, 09:59 PM   #127
ttppll's Avatar
$50 is a great deal, have fun with it!
Tom L.
Old 07-05-2009, 07:39 PM   #128
Suspended
Yea, I race a Vendetta St on carpet and I have seen a few of these truck do really well. What are some things I should replace or mod right off the bat to help with carpet racing with jumps?
Old 07-06-2009, 07:58 AM   #129
Mini_Me's Avatar
Is this the regular or Pro (graphite). Either way, the foam tires for the M18T would offer the best performance traction wise. Especially with the numerous compounds you have choice of.
If this is not the Pro, also invest in the adjustable rear toe in linkages to reduce your rear toe-in as its not needed soo much for carpet.
Oh, also if not the pro, get the nt18T spring set as they are harder, and better suited for carpet racing.
*Have a question on the M18/T line of vehicles? Check the (unofficial) FAQ.
http://forum.teamxray.com/viewtopic.php?t=2524
*Need help finding an Xray supplier? Check the dealer/distributor database.
http://www.teamxray.com/teamxray/other/worldwide.php
Mini_Me is offline   Reply With Quote
Old 07-10-2009, 01:35 AM   #130
Mini_Me's Avatar
Default Xray Seeking feedback
If you are interested or have some thoughts about what you would like to see for potential future projects, please post them in the below thread at the xray forum (membership required).
http://forum.teamxray.com/viewtopic.php?t=9470
Old 08-30-2009, 01:45 AM   #131
Thomas P's Avatar
Made a litle wingmount tutorial for the car...
Wingmount - Xray M18T - Tuturial
Skyrocketbatteries | TpParts - hand made CF parts, straps,Xray chassis etc
Xray M18T Pro - eZrun25A - 7800 - Spectrum - Ko - Gecko
Thomas P is offline   Reply With Quote
Old 09-03-2009, 12:39 PM   #132
Default questions for the m18t experts
hey guys i'm new here.. i've had a m18t with mamba 6800kv for a while now but haven't really played with it yet.. contemplating on selling it but if i don't end up selling it at the price i want, i'm going to keep it... so, if i do end up keeping it... i've heard that i'll need to replace the pinion/spur gears due to the power of the brushless motor... and i'm also looking into lipos.. where can i get a good deal on a lipo charger and some 2s packs? any other tips? thanks in advance!
pokguy is offline   Reply With Quote
Old 09-03-2009, 10:00 PM   #133
Thomas P's Avatar
Pokguy go to www.hobbycity.com checkout zippys or Rinhos 2s lipo
Old 09-04-2009, 07:29 AM   #134
thanks i just did.. there are different "C" rating.. which ones should i be looking at? Whats a good lipo charger recommendation (cheap one) thanks
XRAY M18T w/MAMBA 6800kv RTR for SALE
http://www.rctech.net/forum/r-c-items-sale-trade/324669-fs-mint-xray-m18t-w-mamba-6800kv-fm-tx-rx-250-shipped.html
Old 09-12-2009, 06:32 AM   #135
spaz163's Avatar
This is the Rhino lipo that I use in my M18T, it fits perfectly after you have trimmed the "ears" on the inside of the battery tray.
http://www.hobbycity.com/hobbycity/s...idProduct=7312
As far as the charger, this one works fantastic!! No seperate balancer required because it charges each cell independently through the balance tap. But if you want to use it in this charger on 120VA in your house you will have to aquire a proper power supply. What I did for a power supply is went and found a power supply for a LCD monitor on ebay that had a 12VDC output for about $10 shipped, wired it up to the charger input and done.
http://www.hobbycity.com/hobbycity/s...Charge_Capable
If you want something cheaper and don't mind it taking about 2 hours to charge your pack this charger would work too. It can plug directly into 120 VAC
http://www.hobbycity.com/hobbycity/s...110/240v_Input
spaz163 is offline   Reply With Quote
Forum Jump
Official MT2 RTR Thread PowayLAX1 Electric Off-Road 18 03-20-2007 01:03 PM
Xray M18T/MT/NT Thread thachowman Micro and Mini Scales 2 10-31-2006 07:28 AM
Official Xray M18 ''setup'' thread maximebeauvais Micro and Mini Scales 7 09-06-2006 02:13 AM
Xray M18T Thread!!! LosiFromHell986 Electric Off-Road 10 10-15-2004 12:51 AM
LST Official Thread Whipple81 Monster Trucks 0 10-06-2004 10:30 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
