Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-20-2007, 06:17 PM   #181
i am cornholio's Avatar
when oh when are we going to get foams for the 18 r???? come on tony or brent going crazy we need them
i am cornholio is offline   Reply With Quote
Old 02-21-2007, 07:23 AM   #182
danthrc's Avatar
I'm going to try the Losi Mini T Rear foams. The offest is fine, although you do have to change the axle stubs so the wheel will screw on.
You also have to turn down the diameter to match (or close) to the original.
We have had good luck with it so far.
danthrc is offline   Reply With Quote
Old 02-21-2007, 01:52 PM   #183
how do you change the axle stubs??? from the 18t?? please help
Old 02-28-2007, 11:46 PM   #184
moy
will the 18t foam tires will work on the 18r??
moy is offline   Reply With Quote
Old 03-01-2007, 12:57 AM   #185
gashuffer's Avatar
Moy the rubber ones hook up great. Are you going to a carpet track? if so where?
gashuffer is offline   Reply With Quote
Old 03-01-2007, 01:16 AM   #186
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
anybody interested in a mamba 25 esc by any chance pm me for more info....
ProudSavageOwnr is offline   Reply With Quote
Old 03-01-2007, 12:21 PM   #187
moy
i know that but their hard to find. and the unpainted bodies too...
Old 03-01-2007, 02:38 PM   #188
gashuffer's Avatar
Moy everywhere I called said the R stuff is on back order. Whats up with that? Gizzmos has a bunch of stuff coming in you should call Carol and reserve some stuff while it lasts
Old 03-02-2007, 09:10 AM   #189
danthrc's Avatar
I found some foams made by a company called BSR Racing Tires. They are the foams for the 18T.
The offset is 5mm wider than the stock R rim, but the rim is a bit smaller in diameter so no foam needs to be trued off to get them under the body.
I just cut out the wheel wells a little and allowed enough room for the shocks to work. They hook up fine.
Here are a few pics
Old 03-02-2007, 04:59 PM   #190
did you use the 18 t axles???
Old 03-02-2007, 05:25 PM   #191
danthrc's Avatar
Yes I did.
After running it today, I will be going back to rubber. I run on an outdoor asphalt track and the foams worked functionally good. The grip was not quite what I wanted. They would probably work great on carpet.
Rubber seems to be alot more consistant and predictable outdoors.
Old 03-03-2007, 07:58 PM   #192
Send a message via AIM to Nexus
This car is hilariously fun to drive!!!!
In stock trim it's a little edgy on carpet but makes it a blast trying to hold on to it.
The BSR foam solution looks pretty good. Has anyone else found any other foams that might be "bolt-on" without any mods? Or just any foams that fit...
Nexus is offline   Reply With Quote
Old 03-04-2007, 12:55 AM   #193
gashuffer's Avatar
Anyone want to trade a Citreon body for a camino
Old 03-11-2007, 06:50 AM   #194
I GUYS I'M A NEW SOUL CONVERTED IN TO R/C.
I JUST GOT A 18R,AND ITS FUN TO DRIVE SO ANY TIPS AND ADVICE ARE WELCOME.I'M LOOKING FOR A TRACK AND A CLUB,SO IF YOU KNOW ANY IN
McHENRY COUNTY IN ILLINOIS OR WALTWORTH CO. IN WISCONSIN LET ME KNOW.
enrique60033 is offline   Reply With Quote
Old 03-12-2007, 09:33 AM   #195
Default suggestions
hello,
I have an 18R and I race on a small local carpet track.
If I were to replace the stock servo with a differant one, would it improve the steering of the car? if so, what are the recommended servos that people would suggest that are a drop-on replacement and are not too expensive?
The rules at my track are that I can change anything, except the tire and I must use a closed-can brushed motor.
There have been several instances of people "frying" there stock motor. Is there a recommended motor that meets the closed-can brushed requirement that would be a good replacement?
What weight oil is the stock oil in the shocks?
thanks,
tim
rc_speed is offline   Reply With Quote
Forum Jump
RC18B with RC18R wheels vs Wabash road rage Wyle E. Coyote Micro and Mini Scales 2 05-24-2008 06:39 AM
BEST 1.10 ON ROAD TOURING CAR minnesh Electric On-Road 37 05-11-2007 11:09 AM
Where to Run Road Course Touring kcburnzz Minnesota and North/South Dakota Racing 10 05-25-2004 09:51 PM
OVA T4 XP 1/10 4WD touring-on-road rccplayer R/C Items: For Sale/Trade 11 02-11-2003 04:19 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
