Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-05-2007, 06:10 PM   #136
Send a message via AIM to T1bobo
Originally Posted by ae4ever
My setup for the outdoor asphalt track in San Antonio, TX.
Front:
Camber: Stock, Caster: Stock, Height: 5mm
Shock: Threaded Alm., 25wt, Gold spring, Middle hole on tower
Rear:
Camber: Stock, height: 5mm, toe: Stock
Shock: Threaded Alm., 25wt, Silver spring, Middle hole on tower
Tyres: Stock, Body: Kamino, Motor: AE370
Track: Medium-low grip
I used two shock o-rings for limiters in the shocks, Modified the stock sterring rack as per instructions on www.competitionX.com, Reconfigured the stock battery pack to a stick pack layout to allow battery position adjustment(front to rear), And my front diff is Med. tight and the rear diff is loose.
Still waining for adjustable camber links
Thank you for the setup but i have a Q about the o-rings in the shocks is there another way to take the droop out or is this the best way!!
T1bobo is offline   Reply With Quote
Old 02-05-2007, 07:02 PM   #137
mentallylost's Avatar
It's the easiest way. But you could also cut some rubber fuel tubing and slide it around the shocks shaft instead. Just make sure that if you do the tubing instead that the tubing is cut to the same lengths or the car will not sit level.
mentallylost is offline   Reply With Quote
Old 02-05-2007, 07:07 PM   #138
ae4ever's Avatar
To the best of my knowledge 0-rings or something similar (cut fuel tubing, plastic spacers) are the only way to adjust droop on the 18R.
ae4ever is offline   Reply With Quote
Old 02-05-2007, 07:11 PM   #139
Dan, My LHS has the dogbones/outdrive springs in stock.
Google T&T Hobbies - Plano TX. Ask for Joe (owner) or Jason. I am sure they can mail some to you.
bbking9 is offline   Reply With Quote
Old 02-05-2007, 07:22 PM   #140
Could you be more detail in the tubbing method!
Old 02-05-2007, 07:26 PM   #141
Do you race at T&T? im trying to figure out who you are lol
Old 02-05-2007, 07:54 PM   #142
gashuffer's Avatar
I have the o-rings and it works fine, fill the shocks all the way and invert them when you install them cause they leak. Stock springs with 25
gashuffer is offline   Reply With Quote
Old 02-05-2007, 09:08 PM   #143
I think i should have said a few post back that this is a 18B not the R but i think the only things that are diffrent are the A-arms shock towers and body am i right i think i could still use these things to get my car full blown onroad am i right?
Old 02-06-2007, 04:32 PM   #144
ae4ever's Avatar
The stock o-rings work fine but they seem to stick a little when the shocks are compressed, silicone o-rings won't swell like rubber ones do, and builds a smother shock.
Old 02-06-2007, 04:57 PM   #145
Here's a pic from http://www.competitionx.com/Support_Pages/18T.html on how to adjust the droop. For the fuel tubing instead of the o-rings just cut the tubing and put it in place of the o-rings.
As far as leaking shocks go... try this for a fix. I swear by it. It's been 8 months or so and still no leaks in any of my RC18's.
http://www.freewebs.com/crookedjracing/shockrebuild.htm
Old 02-06-2007, 06:56 PM   #146
just got done putting the tubbing in my shocks and it droped it alittle front and back lol this is the first step to making it a pure onroad killer
Old 02-06-2007, 07:50 PM   #147
What do you guys think is the next step to completing my task at hand?
Old 02-07-2007, 12:43 PM   #148
danthrc's Avatar
Are there any stock pre mounted wheel/tires for the 18R or do we have to mount them?
danthrc is offline   Reply With Quote
Old 02-07-2007, 04:28 PM   #149
Dan - the only ones I have seen are the black and whites wheels with the stock tires already mounted and glued.
Old 02-07-2007, 06:30 PM   #150
danthrc's Avatar
Thanks BB that is what im looking for... I talked to AE today and most of the R parts are back ordered because of some sort of auto entry computer glitch. I was told it would be a few weeks before things got back on track.
I have about wore out my tires!
Forum Jump
RC18B with RC18R wheels vs Wabash road rage Wyle E. Coyote Micro and Mini Scales 2 05-24-2008 06:39 AM
BEST 1.10 ON ROAD TOURING CAR minnesh Electric On-Road 37 05-11-2007 11:09 AM
Where to Run Road Course Touring kcburnzz Minnesota and North/South Dakota Racing 10 05-25-2004 09:51 PM
OVA T4 XP 1/10 4WD touring-on-road rccplayer R/C Items: For Sale/Trade 11 02-11-2003 04:19 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
