BIG BLOCK OVER HEAT! >
Old 06-19-2007, 04:09 PM
racing_jason's Avatar
Default BIG BLOCK OVER HEAT!
i have a 18B and i put a orion BIG block in it. im just running it in my alley behind my house that is fairly smooth. no matter what i do to this motor the thing comes off to the point where my finger cant touch it with out being burned! no matter what the pinion size is it still comes off hot! this is only about 3 min of running with complete cool downs in between runs.
is this normal for this motor?
racing_jason is offline
Old 06-19-2007, 05:14 PM
Bermbuster's Avatar
how are you setting your gear mesh??? does the vehicle have a bind in the drivetrain??? a tight mesh or something binding will cause your motor to run hot.....
Bermbuster is offline
Old 06-19-2007, 08:43 PM
I've been racing my RC18T with a Big Block using a 17 tooth pinion, it reaches about 150 degrees after a 6 minute race.
AreCee is offline
Old 06-20-2007, 07:54 PM
yeah the mesh is good and the thing rolls freely. the pinion is a 17 also should i try to go up since im getting alot of open throtle. also when i run it on a motor run on a charger @ 8 volts it doesnt get hot?
Old 06-22-2007, 11:29 AM
joe of loath's Avatar
the motor will only get hot under load, so the motor will stay cool if its just spinning freely, or spinning the wheels when attatched to the charger.
joe of loath is offline
Old 07-14-2007, 11:49 AM
ijump's Avatar
is the motor gettin genough airflow because that was the problem with mine and i had to get a new body because of it
ijump is offline
