need help asap mini t baja
hey guys i got a mini t baja recently it has only been driven once and i got it out today charged the battery and plugged it in but nothing happend so i tried another battery nothing happened so i change my radio batteries nothing happened i really need help
it also makes a sort of buzzing/clicking sound when turned on and stationary
hey, turn everything on and roll the back wheels fast on the floor, if they start moving your engine is hooped, it happened to mine,
Does your steering work? Make sure all the wires are properly plugged in and in the right order, do the same color lights come on the transmitter (on the back) and reciever? Try those and you will most likely find your problem. Don't roll the car fast on the floor, that won't solve anything, just unscrew the motor, leave the pinion on and see if it turns smoothly by hand. If it feels rough or has excessive play you do have a bad motor, if the servo doesn't work then there are a number of things that could be wrong and you have to start trouble shooting.
