Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 03-31-2007, 08:52 AM   #1
jaejw1's Avatar
Send a message via AIM to jaejw1
Default VENDETTA BL motor reviews.. pros/cons
this is just my take on things.. not the word of god.. just what i have experienced ,,so take it with a grain of salt.. and with the introduction of the new ST im sure many ppl will want to find a good BL motor to put in there..
testing was at socal raceway a dirt track offroad supercross style track for 10th scale electrics
the buggy is sitting on half8th buggy wheels with proline crime fighter tires
the truggy is sitting on half8th ST wheels with the tires that come stock with it.. kyosho,,3racing
MAMBA 8000kv,, first brushless i tried in the detta
pro- vry fast.. would have been great if it were a 400 can
cons- extreme heat from usage
gearing-12/49
WRAITH 7K,, second brushless once the 8000kv died
pro- just as fast as the 8000kv
cons - another extremely hot motor
gearing -12/49 made it hot but 13/49 made it smokin hot
GH4700,, third motor.. perfect fit,, loved the heat sink
pro,- fast motor not as fast as 8000kv but still fast,, cooled down really fast for the buggy
con- hot.. heat issues,, did not like the half8th ST tires on the vendetta ST
gearing- 19/45 good for buggy bad for truggy even 16/45 was bad extreme heat and not fast at all
AON4900,, fourth motor after gh4700 died,, i thought this was the ticket
pro- fast but not what i thought,, i expected great things from this motor.. it was ok.. prfferred the gh4700 over this one.
con- i idnt expect it to get as hot as it did.. and the claims of it being a torque monster , it just didnt like the gearing
gearing-19/45
GH3600,, tried this motor on the on the buggy and it was decent i was shocked ,,,
pro - decent speed for the buggy and more than decent for the truggy
gearing - 19/41 for both the buggy and truggy
AMMO 28-35-3900,,,, best thing sinced sliced bread.. this is the mamba 8000kv for the truggy,,
pro- really fast.. impressed with its speed ,, i use this motor to race with
con- gets a lil warmer than i want.. but not anywhere near the heat of the others up top,, ball diffs are needed
PERMAX 400/4D,,,, this would be the C4 for the buggy and truggy,, this thing continues to impress me
pro-can be geared for whatever track.. stays cooler than any motor i have used ,, this is extremely awesom
con- price,, and i cant get it to heat up,, have to upgrade to ball diffs
gearing -buggy 16/41,,19/45,,1941. truggy 16/41,,19/45(which im scared to try.. dont know what i will break)
MONGOOSE 13.5,,,, test conducted at pegasus hobbies on an outdoor 10th scale dirt offroad track.. well after comparing gearing ratios with the 13.5 and trying to get something equal to the permax i figured that a gearing of 16/45 would have been what i needed.. but after 3minutes of running just to have it shut down i wasnt pleased.. i geared it at 13/49 and was completely disappointed at the speeds i was getting.. but it didnt over heat but it couldnt clear the larger jumps..
MONGOOSE 8.5,, conducted the same day as the 13.5. with pretty much the same results.. but gearing at 13/49 the motor still went into thermal and wasnt nearly as fast as the permax.. both are very smooth systems but just not made for larger dirt offroad tracks.. atleast not for the vendetta ... smaller tracks,, yes
EDIT CHANGE AS OF NOW.. 05-07-08,,,,,
MY NEW REFERENCE SYSTEM
NEU 1105/1.5y
19/45 gearing
evo2 1600mah flight power lipo
,,, i cant even describe the feeling.. the power,, the speed..
10th scale street tires with suspension set up for dirt track,,, wheelies on demand.. rlling wheelies.. i have no idea what the top speed is.. the car cant keep up with the tire spin..
IM CURRENTLY RUNNING THIS MOTOR AT 13/45 AND IM COMPLETELY HAPPY WITH IT.. VERY FAST.. VERY POWERFUL.. AND NO HEAT ISSUES.. 7000KV MOTOR RUNNING VERY EFFICIENTLY.. COULDNT ASK FOR ANYTHING MORE.. the current gearing isnt used for speed runs but on the track it is more than enoough.. runs very well with 10th and 8th scale brushless vehicles..
vendetta videos.. http://www.rcuniverse.com/forum/m_5684344/tm.htm
motor review
http://www.rcuniverse.com/forum/m_5643067/tm.htm
http://www.rctech.net/forum/micro-mini-scales/156814-vendetta-bl-motor-reviews-pros-cons.html
tire review
http://www.rcuniverse.com/forum/m_6000527/tm.htm
jaejw1 is offline   Reply With Quote
Old 03-31-2007, 12:45 PM   #2
I've run most of those in my Detta. Settled on the same one as you. It is a very good match to the Detta.
Another good one that I used for a while is an ourunner e-flite 370. Lower kv required 3 cell and bigger pinion. Efficiency was through the roof! About an hour run time.
Even with the 3 cell, I don't think it would be the ticket on a bigger track like you run on.
duneland is offline   Reply With Quote
Old 03-31-2007, 12:48 PM   #3
MADMAN23's Avatar
Trader Rating: 6 (88%+)
Send a message via AIM to MADMAN23
HOLE SMOKE'S jaejw1 i thank you cover all the bl system's lol what the best? and what 1 are you useing now?
MADMAN23 is offline   Reply With Quote
Old 03-31-2007, 02:44 PM   #4
jaejw1's Avatar
for the buggy I use the permax
for the truggy I use the ammo
motor review
tire review
Old 03-31-2007, 05:19 PM   #5
Bermbuster's Avatar
nice review......
have you upgraded to ball diffs?
Bermbuster is offline   Reply With Quote
Old 03-31-2007, 06:52 PM   #6
jaejw1's Avatar
I took the ball diffs out the buggy cause I was getting ready for a race and I kept stripping the gear diffs,,,,
so right now the truggy has ball diffs and the buggy has nothing... but that will change soon
motor review
tire review
Old 04-01-2007, 05:56 PM   #7
imjonah's Avatar
Default Brushless ESC
What ESC are you recommending?
The Mambas are programmable via cable and computer that a factor?
Are the others as programmable or programmable enough?
Would you change your reccomendation if Vendetta was to be used on large 1/10 asphalt parking lot road course with no jumps?
imjonah is offline   Reply With Quote
Old 04-01-2007, 06:38 PM   #8
jaejw1's Avatar
mamba with ammo
quark with permax
,, i dont care for onroad asphalt.. but it will still do well.. there is a video of a detta racing a rc18 on assphalt.. i will post it later
motor review
tire review
Old 04-01-2007, 06:39 PM   #9
jaejw1's Avatar
http://www.youtube.com/watch?v=x78gOX4tg5A
motor review
tire review
Old 04-06-2007, 07:04 AM   #10
MADMAN23's Avatar
hi havn't talk to you in a while.. how much for the esc and the motor?
Old 04-06-2007, 07:54 AM   #11
jaejw1's Avatar
which combo.
motor review
tire review
Old 04-06-2007, 11:56 AM   #12
MADMAN23's Avatar
well both .....mamba with ammo
quark with permax....
Old 04-06-2007, 01:05 PM   #13
jaejw1's Avatar
the motors cost the same about 69 bux... and the esc will vary..
check towerhobbies.com
mamba 25a esc
quark pro car 33a
multiplex permax 400/4d
great planes ammo 28-35-3900
motor review
tire review
Old 04-07-2007, 06:24 AM   #14
MADMAN23's Avatar
which 1 in your opion is the best the mamba or the quark?
Old 04-07-2007, 08:25 AM   #15
jaejw1's Avatar
it depends on the motor,,,,, but the Quark has more functions it seems but the mamba is easier to set up,,,,,,
the mamba works well with the ammo and so does the Quark
but only the Quark works best with the permax
I like both the Quark did seem a lil smoother though
motor review
tire review
Forum Jump
Pros/Cons on AE 18R Huffpie Micro and Mini Scales 5 12-07-2008 06:11 PM
Pros and cons about motor FAN Jochim_18 Electric On-Road 53 07-10-2006 01:09 PM
pros and cons _nick_ Electric Off-Road 6 02-28-2006 07:03 AM
Pros and Cons! Bobby J Electric On-Road 6 01-06-2005 06:15 AM
pros and cons of XXX-S & TC3 jiggamacdaddy Electric On-Road 15 04-30-2003 09:09 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
