Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 03-29-2009, 08:31 PM   #46
trdsupra88's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to trdsupra88
bump...interesting thread...I ended up going with the CC SW ESC and a cheap motor from hobby city, 370 and 4400kv, I found some packs to try out too...1450mah 25c 2s...$15 for the motor and $15 for the batteries and Ill have a CC 8000kv motor for a spare...After reading this thread I will end up going with the Ammo motor after a while...
I cut my own hair
trdsupra88 is offline   Reply With Quote
Old 03-29-2009, 10:12 PM   #47
jaejw1's Avatar
Send a message via AIM to jaejw1
keep us posted on how everything works out for you..
vendetta videos.. http://www.rcuniverse.com/forum/m_5684344/tm.htm
motor review
http://www.rcuniverse.com/forum/m_5643067/tm.htm
http://www.rctech.net/forum/micro-mini-scales/156814-vendetta-bl-motor-reviews-pros-cons.html
tire review
http://www.rcuniverse.com/forum/m_6000527/tm.htm
jaejw1 is offline   Reply With Quote
Old 03-29-2009, 10:18 PM   #48
trdsupra88's Avatar
I will, thanks again for the great review...you are helping alot of people...
I cut my own hair
Old 03-31-2009, 01:46 AM   #49
heavy's Avatar
Hi Guys
I've got an Anderson MB4 which is basically a Vendetta buggy by another name. i have an Orion brushless motor that has a 2mm shaft.
Does anyone know if anyone makes .6module pinions with a 2mm centre hole ?
Email Heavy
Action RC Web - the South Qld RC info line.
Action RC - The Shop
Schumacher, CORE, Speed Passion, Protoform and much more.
South Qld Onroad Interclub
heavy is offline   Reply With Quote
Old 03-31-2009, 02:31 AM   #50
buttmonkey1969's Avatar
Default .6 module pinion with 2mm shaft
Heavy,
unfortunately no, much to the frustration of many vendetta owners.
Two options,
a sleeve............ adapting Duratrax alu pinions w/ 2.3mm shaft, (or 3.2mm shaft steel robinson pinions)
or
....... adapt an rc18 spur to fit onto a vendetta spur.
hope that helps m8
Carl
Schumacher CAT SWB, XLS, ProCAT, SX Lipo:
1/18th:Duratrax; Vendetta Buggy, ST, Rally~LRP;S18 TC FT
Team Durango DEX410
buttmonkey1969 is offline   Reply With Quote
Old 03-31-2009, 02:45 AM   #51
heavy's Avatar
That's not good news. Guess I'll have to look for a motor with a 2.3mm shaft - should have researched the whole thing a lot better. So used to 1/10th where virtually every motor / pinion fits everything. Boring, another time period where I can't run the 1/18th.
Suppose I could take the easy way out and put a brushed in.
Email Heavy
Old 03-31-2009, 05:42 AM   #52
Default motor options
If you're going to start again with a new motor; I'd recommend the Novak 380 10.5 ...excellent all round performer, and it comes with a 3.2mm shaft so your 1/10th pinions should be a direct fit.
Carl
Team Durango DEX410
Old 03-31-2009, 08:27 AM   #53
Suspended
Hi Guys
Hate to say it but those smaller 20mm BL motors with 2mm shafts don't have enough guts to power a MB4 without overheating. I'd suggest looking into a 370 or larger BL motor with a larger shaft diameter that gives you more pinion options and won't overheat running the car.
Carl
x1
Mongoose system is a good choice
Lightin' is offline   Reply With Quote
Old 03-31-2009, 03:32 PM   #54
Dieselpower's Avatar
Trader Rating: 18 (100%+)
370 motors are really to same as 280s or 300s......That being said, they're BL counterparts (ie....mambas, C4s and the like) are 180s. Just some clarafication.
You can run a Mamba in a vendetta, though I would not recommend it as you'll have to gear it way, way down in order to keep from the aformentioned overheating (not to mention cogging) issues.
Atomic used to or still does make .06 mod pinions with a 2mm hole, but your best bet for finding those is from HK.
Kinda on a different note, but if anyone ever wanted to run a VR3 in an AE or losi........I stumbled across these a while ago.
http://www3.towerhobbies.com/cgi-bin...?&I=LXRXN1&P=7
The dude abides
www.18thscaleracing.com
www.rcmadness.com (my carpet home)
www.rchr.biz (my dirt home)
Dieselpower is offline   Reply With Quote
Old 03-31-2009, 04:19 PM   #55
Suspended
Now I'm confused, I thought the number had to do with can size.
I have 280, 370 and 380 brushed motors and (using digital calipers) the 370 is a little larger and the 380 is a lot larger, just like 540 motors are larger yet.
Old 03-31-2009, 05:46 PM   #56
I stand corrected
A Mamba in an LRP S18/DuraTrax Vendetta Graphite Chassis Set (yet to be released) could work...
You can run a Mamba in a vendetta, though I would not recommend it as you'll have to gear it way, way down in order to keep from the aforementioned overheating (not to mention cogging) issues.
Team Durango DEX410
Old 03-31-2009, 08:01 PM   #57
I really should've said that they are generally the same size...280s and 300s are about the same diameter, whereas (as you said) the 370 is slightly larger.
There really hadn't been a market for motors other then 540s in cars until mini vehicles hit the shelves.
Aircraft motors are basically grouped as 300s, 400s and so forth. 280s and 370 are really 300s and 380s are 400s.
Dimensions may vary slightly from one manufacturer to another as well.
The dude abides
Old 04-01-2009, 04:34 AM   #58
heavy's Avatar
Atomic now appear to only make 2mm pinions in 48 pitch not .6 module
Email Heavy
Old 04-01-2009, 04:36 PM   #59
this pinion should fit :48 pitch AND .6 module to suit 2mm shaft; (which is what you are looking for)
Team Durango DEX410
Old 04-02-2009, 01:55 PM   #60
heavy's Avatar
48 pitch and .6 mod are not the same - I tried a 48p pinion and the noise alone confirms this.
I checked with Atomic and they only make 48p in 2mm shaft size.
I bought a motor with a standard 1/8 shaft so I can use the standard 1/10th size pinions.
Thanks for your help everyone.
Email Heavy
Forum Jump
Pros/Cons on AE 18R Huffpie Micro and Mini Scales 5 12-07-2008 06:11 PM
Pros and cons about motor FAN Jochim_18 Electric On-Road 53 07-10-2006 01:09 PM
pros and cons _nick_ Electric Off-Road 6 02-28-2006 07:03 AM
Pros and Cons! Bobby J Electric On-Road 6 01-06-2005 06:15 AM
pros and cons of XXX-S & TC3 jiggamacdaddy Electric On-Road 15 04-30-2003 09:09 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
