It's unlikely that you will have better luck with the Ammo. The permax is a higher quality motor. Your quark, battery, or connectors are likely to blame. First, re-solder all connections. Make shure you have high quality connectors between battery and esc. The 1/10 sidewinder is a good idea, but I don't know where I would put one in a Vendetta chassis.
****RATFactor Racing Products**** www.ratfactorracing.com****ratfactor@live.com**** www.midwestseries.com
motor review
http://www.rcuniverse.com/forum/m_5643067/tm.htm
http://www.rctech.net/forum/micro-mini-scales/156814-vendetta-bl-motor-reviews-pros-cons.html
After frying my mongoose I switched to my RS as a back up, I felt a noticeable difference using my RS tuning wise and the speed control was cold to touch, seriously the thing was like it was turned off. I guess being able to go in and fine tune profile settings made for a much smoother feeling,better braking combo.
motor review
A lot of the fast guys over in the UK have been running the RS with the goose motors for a while now with great results. That'll definately be my next upgrade for sure. I've been a die hard Novak fan ever since the advent of ESCs, but the new Tekin stuff is great. LVCs on almost every model and super small footprints to boot.
motor review
I did it with one of my Dettas and it worked surprisingly well, better than I thought.
what gearing are u running now with the tekin esc... and what temps are u getting,,,
and what gearing and temps were u getting with the mongoose esc..
Never use a temp gun, but the gearing I run is either stock to 2up, 2down pinion. The Tekin RS esc is very expensive and I would never buy one specifically for a mini car,but with such great results, I highly recommend them for serious racers.
