detta uses .6 module, most other micros use .5 module. Both pitchs are metric. If by 'regular' you mean 48 pitch, Xray and brp are the only two that come to mind, using that pitch.
EDIT CHANGE AS OF NOW.. 05-07-08,,,,, MY NEW REFERENCE SYSTEM
NEU 1105/1.5y
19/45 gearing
evo2 1600mah flight power lipo
,,, i cant even describe the feeling.. the power,, the speed..
10th scale street tires with suspension set up for dirt track,,, wheelies on demand.. rlling wheelies.. i have no idea what the top speed is.. the car cant keep up with the tire spin..
I got the other 1600 pack from RC Hobby Sports. I agree. It barely gets above room temperature with my setup in my my M18T pro. I also have never experienced cells more in balance. I know you got dibs on the next ones coming in, but I'm grabbing one from the next order after!
*Have a question on the M18/T line of vehicles? Check the (unofficial) FAQ.
http://forum.teamxray.com/viewtopic.php?t=2524
*Need help finding an Xray supplier? Check the dealer/distributor database.
http://www.teamxray.com/teamxray/other/worldwide.php
hey... how are you... well i just ordered it.. just one for now.. but good god dude.. i couldnt imagine what i was seeing and experiencing.. my next run will test runtime... since my tire flew off on the last one i never got a good timing done.. using loctite now so i should not have a problem...
hey Jaejw1 I just converted my buggy to a truggy and am currently running a ammo and tekin esc works good but do you ever strip your balldiffs? (i got balldiffs btw) I stripped my rear one once. But my question is what gearing do you run and do you shim the diffs at all? Thanks for the help
i run ball diffs in the rears.. im expecting them to go out on me after this test run... but i was always blowing them because of the power from the motors... never had a problem with them from the ammo motor though..
the thing i have done so far that has worked and allowed my diffs to atleast last for 4 runs... i use an extra diff plate on the shorter outdrive side... this forces the diff gear to press firmly against the shaft gear and allows the gears to last a lil longer.... this is a trick i did with my rc18t nd it worked very well.. and im pleased with the results so far...
i used the ammo 3900 and had it geared at 19/41 for racing.. the same as 21/45
Ok thanks, right now i got 1 shim in the rear and it seems to be ok but only got one day on it atm so ill see how it goes. Im running 19/45 but its a small track. More 1/18 scale track so its about perfect. I hope i dont have any diff problems with this motor because i hate diffs lol
8 minutes and 30 seconds of continuous run time... the pack was not hot.. maybe in the very low 100,,,, warm enough to put on my cheeks and not burn... the pack never swelled..
well i will have to practice with it.. but for the larger 10th scale jumps... ha ha ha ha this set up will laugh at them...
but im clearly aware of how much the vendetta can take on a dirt track,, i know not to go balls out on the straights.. i try not to over drive my skills or the ability of the vehicle/set up
lol ya last night was my first race with mine i had no practice because i had a bad wire and put it out for the last qual. round and tqed and then got 2nd in the main because my steering was getting stuck, just bad luck but so far the truggy is alot better then the buggy was to race with
i still prefer the buggy over the truggy.. but only if the track is smooth ... to me the buggy flies better.. but since i dont have a smooth track to run on.. i run my truggy..
will the ammo motor have less cogging issues at low speed. I have the permax and it coggs bad at low speed and when brakes are applied the wheels lock up immediately. btw i have a quark esc if that matters. I am planning on getting the mamba 1/10 sidewinder esc soon. any help would be appriciated.
