Originally Posted by MADMAN23
i have 1 also.. i have a bl .. what size pion should i use in it?
Depends on the track or conditions you want to race in...Is the track tight and technical (cuz you'll want a smaller pinion), is the track wide open without tight turns (then you can get away with a bigger pinion) or are you just trying to racing the thing up & down the street trying to out run real cars (Then anything goes - but probably the bigger the pinion the better)??
Also depends on what motor you are running - i.e., 4900, 5400, 6800, 8000
Shoot a little more info over and there will be a ton of people who can help you out...
WHen I last ran my Half8, I ran a Mini-Rage system, with either the Tekin 6800 or an Aon 4900...but had a 12T pinion on mine with the stock spur gear..
