Team Associated, R/C Driver & Castle Creations
Presents
2007 1/18 Indoor Off Road Nationals
April 13, 14 & 15
Only at R/C Madness in Enfield, CT
$35.00 for the first class (includes a race shirt)
$30.00 each additional class
Top ten in ALL “A” Mains receive awards
Top three in all other mains receive awards
Handout motors in specified classes provided by Reedy
Friday Open practice until 7:00 Club Race starts at 7:00
Saturday 2 rounds of IFMAR qualifying
Sunday one round of last chance IFMAR qualifying followed by mains
Don’t forget the “Super Main” following the “a” Mains where the best drivers & vehicles will compete together for the Manufactures Cup!
TQ awards sponsored by R/C Driver magazine
Best Paint competition on Sunday sponsored by
www.radiocontrolentertainment.com
Xtreme Performance awards provided by Xtreme R/C Cars magazine
Class 1:
4wd Stock Class (Stadium Style)
Sponsored By Reedy
NO modifications to the factory stock chassis
1/18 Rubber Tires ONLY, No touring car tires, No Hex Adapters
Handout Reedy Mini Mod Motor ONLY
No disassembling or altering the motor
Open Electronics
5 or 6 Cells 2/3A Type Battery Packs ONLY (7.2 volts max)
Must use a stadium style truck body
Class 2:
4wd Modified Class (Stadium Style)
Sponsored By Team Associated
Open Chassis
Brushed Motors Up to, not exceeding, 300 in size, No Brushless Motors Allowed
Open 1/18 Tires including foams; No Touring Car Tires, No Hex Adapters
Open Electronics
Battery Voltage not to exceed 8.4 Volts
Class 3:
4wd Brushless/Unlimited Class (Stadium Style)
Sponsored By Quark Brushless
Open Chassis
Open Brushless Motor (only one motor)
Open 1/18 Tires including foams. No Touring Car Tires, No Hex Adapters
Open Electronics
Unlimited Battery Voltage
Class 4:
2wd Stock Class (Stadium Style/Baja)
Sponsored by Team Losi
Open Electronics
Must use a stadium style truck body or Baja Bug Body
Class 5:
2wd Modified Class (Stadium Style)
Sponsored by Team Scream
Open Chassis
Open Electronics
Class 6:
2wd Brushless/Unlimited Class (Stadium Style)
Sponsored By Team Tekin
Open Chassis
Open Electronics
Class 7:
Mini Monster Open
Sponsored by Duratrax
Open Chassis
Open Motor(s) not to exceed 2. Brushed or Brushless
No Foam Tire or touring car tires, 1/18th Monster Truck Tires ONLY
Tires must be AT LEAST 2 ˝” tall when mounted on rims
Open Electronics
Must use a Mini Monster type truck body or Stadium Truck Body
Class 8:
Novice Class
Sponsored by SMC
12-Years-Old or Younger ONLY (no 'ringers')
Must Run Stock Factory Chassis
NO modifications to the stock chassis
1/18 Rubber Tires ONLY, No Touring Car Tires
Factory Stock Speed Control ONLY
5 or 6 Cells Pre-Built 2/3A Type Battery Packs ONLY. (7.2 volts)
Class 9:
1/18 Buggy Open
Sponsored by ApogeePacks.com
Open Chassis
Open Motor
1/18 Rubber Buggy Tires. No Touring Car Sized Tires or Foam Tires or Hex Adapters
Must run narrow front tires, (similar to the RC18B or Duratrax Vendetta)
Front tires must be less than 1” wide when mounted on rims
No truck front tires/rims. (No wide front tires/rims)
Open Electronics
Open battery voltage
Must run a buggy body with wing
Class 10:
1/18 Buggy Stock/Spec (RC18B, Vendetta ONLY!)
Must Run Stock Factory Chassis.
Factory Tires & Rims ONLY. NO Aftermarket Tires or Rims
Must use factory motor. (The motor that came with the car)
No disassembling or altering the motor in any way
Must use factory speed control & servo.
The ONLY allowable upgrades are as follows: adjustable turnbuckles,
motor heat sink, and aluminum steering knuckles on the Vendetta.
May use different battery connectors.
NO OTHER CHANGES ALLOWED
Must use stock buggy body and wing. May be custom painted
Class 11:
18R Onroad Class (RC18R ONLY)
Sponsored by Team Associated
Hand-out Reedy Mod Motor
adjustable turnbuckles, motor heat sink,
Must use stock AE Citroen, Kamino, Mitusbishi or other 18R bodies made by AE.
Bodies may be custom painted
Misc……
These rules were made to accommodate the majority of hobby shop grade 1/18 vehicles on the market as of 12-1-06. They include the RC18 series, Mini T, M18T, M18MT Mini LST, Baja Bug, Mini Quake, Vendetta, MiniZilla, Mini Giant, Spyder, Blade, Thunder Tiger ZT2, Thunder Tiger ZK2, LRP Shark Truck or equivalent. The Mini Inferno ST is allowed to run in the Mini Monster class
• Aftermarket chassis is allowed in all classes but it may not make the vehicle wider or longer than intended by the manufacturer (except for classes 8, 10 and 11)
• Aftermarket A-Arms are allowed in all classes but they may not make the vehicle wider than intended by the manufacturer (except for classes 10 and 11)
• No Sub C sized cells in ANY class
• No 540 Sized motors in any class
