Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Like Tree15Likes
Old 05-30-2017, 01:02 PM   #1516
Originally Posted by rack View Post
I installed A PN Double A-Arm Front Suspension on my MR-03 now the front is bottoming out. What can I do to limited the travel so it won't bottom out and spin out on me.
Did you see the spacers for springs ? PN sell aluminiun spacers
Pickthall is offline   Reply With Quote
Old 05-31-2017, 06:03 PM   #1517
davidwp's Avatar
I purchased this Kyosho Mini Z MFB01 Formula 1 McLaren Mercedes-Benz MP4-16 No.3 Mika Häkkinen a long time ago and is has rock hard, cracked tires. What is the exact replacement tire? I prefer rubber rather than foam is that is possible.
Thanks -
David Palmeter
Started in 1968, back at it w/grandkids
- two Tamiya F103 Ferrari 412T1 Berger /Jimmy Murphy (Sorta)
- Radio Shack/Verdikt Conversion
http://palmeter.com/rcmodels001/
davidwp is offline   Reply With Quote
Old 06-01-2017, 12:22 AM   #1518
SteveP's Avatar
You'll want to get the MFT01-30R tires for the rear and the MFT01-30F tires for the front. Kyosho America has them in stock.
High Grip Front Tire(30°)
DIS - High Grip Rear Tire(30?)
SteveP is offline   Reply With Quote
Old 06-25-2017, 02:28 PM   #1519
Default kyosho mr03 mm carpet setup
hi, i have the kyosho mr03w mm with ferrari 458 body. i play in carpet track can you help me with some setups. i have a lot of option parts like friction , tplates , camper , etc . and what tires its better for carpet.
thank you
sotirisn12 is offline   Reply With Quote
Old 07-10-2017, 01:09 PM   #1520
Default 2017 KO Propo Mini-Z Grand Prix
Get your Mini-Z's ready. 2017 KO Propo Mini-Z Grand Prix is in a few weeks. There will be great racing and fun. Also plenty of raffle prizes. Come on down and race or just catch the action.
Please let me know if you have any questions.
Date: July 22, 2017
Classes: (Minimum 6 drivers to make a class)
 Novice
 Sportsman Mod
 Modified GT
 F1
 Mini 90mm
 Pan Car
Last day for EARLY sign up: June 24, 2017
 $30 first class, $15 each additional class(Any sign up after June 24th will be an additional $10/Class entered)
 T-Shirts pre-order for additional cost
Last day to sign up: July 8, 2017
Inside Line Racing
95Phelan Ave. Suite 4
San Jose, CA 95112
Payment must be received before June 24, 2017 for early entry.
Pay in person, by phone, or by PayPal to [email protected]
E-mail [email protected] or call (408) 297-4050 if you have
any questions.
www.InsideLineRacing.com
Z_408 is offline   Reply With Quote
Old 07-10-2017, 10:13 PM   #1521
KA2AEV's Avatar
Kind of wish we had something like this over here on the East Coast!
Best of Luck to All of the Drivers!
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Old 07-13-2017, 06:51 PM   #1522
I just picked up a PN Racing 70T motor for my M03 Sport. Do I need to add any external capacitors to the new motor, or can I run it as-is?
I appreciate any input.
curt60 is offline   Reply With Quote
Old 07-16-2017, 05:44 AM   #1523
Trader Rating: 15 (100%+)
The PN 70T can be used with the 03S without additional capacitors but the safety is questionable. Even PN states not to use it. An issue arises when connecting the motor leads to the circuit board. The eyelets on the motor wires are a bit large for the overall area which can lead to them coming in contact with a tiny component between the motor screw holes. If this occurs you will instantly release all the smoke from the PC board rendering it useless. The best solution is to cut the eyelets off the motor wires, strip the ends back on the wires and properly "tin" them. Then de solder the ends from the stock motor and re solder them to the 70T. Pay close attention when re installing the motor screws. when you insert the screw into the hole rotate it slightly to the left until you hear or feel it drop into the existing screw threads. Then tighten the screw. If you do not follow this procedure you will soon be replacing the chassis as you strip out the attaching points.
mleemor60 is offline   Reply With Quote
Old 07-16-2017, 03:43 PM   #1524
That's great feedback. I appreciate the response!
Old 08-20-2017, 06:43 AM   #1525
rack's Avatar
Trader Rating: 64 (100%+)
I am looking for a transmitter for my MR-03 2.4ghz for a left-handed driver.
rack is offline   Reply With Quote
Old 08-20-2017, 08:13 AM   #1526
If you are looking for something for 2.4 ASF you are limited. If it is the 2.4 Sports series there is the Kyosho KT 432P which is switchable.
Old 08-20-2017, 08:56 AM   #1527
rack's Avatar
No it is the MR-03ve
Old 08-20-2017, 10:29 AM   #1528
Kyosho EX6 is buildable for left handers. Really good radio too. Pricey but you get what you pay for in quality.
Old 08-20-2017, 12:05 PM   #1529
rack's Avatar
ok thank you
Old 08-22-2017, 06:10 AM   #1530
This question is from Flanker0408 ( Frank )
More Questions of My Kyosho MR-03 VE PRO
Hi guys,
Before I got into the Mini-Z hobby, luckily I found this awesome forum and I asked a couple of questions in my old thread. Special thanks go to NoBrainer and mleemor60, thank you very much for your helpful suggestions.
I ended up getting a MR-03 VE Pro GP chassis and a McLaren body. I am running Kyosho 30 deg tires up front and 20 on rear. I put a 5600kv motor on the chassis to meet the rules of my local group. I am using the gyro unit. I have not upgraded any other optional parts yet. Last weekend, my local group held a track day and I had some test run on the RCP track. The car is not running very well when cornering and I would like to ask some questions. Any suggestions are definitely welcome
(1) The car tends to over steer when turning right and under steer when turning left, how to fix it? I have disassembled the ball diff and greased it. Is it because the diff is too loose/ tight? Or maybe something else is wrong?
(2) I checked out the PN Racing Precision Gear Diff. Regarding the performance, especially cornering, is it better than the stock ball diff on MR-03? What are the general advantages/ disadvantages of ball/ gear diff? If it was better, which PN Gear Diff should I get, MR2055M or MR2055P? My MR-03 has a Kyosho aluminum MML motor mount.
(3) I have ordered the camber 1 steering knuckle and toe-in/ toe-out steering linkage set. What should I use if I want to fix the problem I mentioned in (1)?
Thank you very much!
Regards,
Frank
Tim3 is offline   Reply With Quote
Associated, HPI Micro, Kyosho Mini Z, Xray M18, Losi Mini T unsponsored Australia Wanted to Buy 9 06-23-2017 07:36 AM
Wanted-Associated, HPI Micro, Kyosho Mini Z, Xray M18, Losi Mini unsponsored R/C Items: For Sale/Trade 0 05-19-2008 04:54 PM
F/S Brand-new Kyosho mini-starter box for Nitro Mini-Inferno 09 nolan_racing R/C Items: For Sale/Trade 8 01-09-2008 09:23 AM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
