Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 12-18-2006, 06:05 PM   #1
oXYnary's Avatar
Send a message via AIM to oXYnary Send a message via Yahoo to oXYnary
Micro Servo Torque Needs (Onroad)
Im trying to decide on a new servo for when I get a m18 pro. I was going for the multiplex polo digi 4 at first since its a perfect fit, great speed and torque, and uses the stock servo saver.
Multiplex Polo Digi 4
(4.8V)
Torque: 39 ounces
Speed .10 sec.
-ball bearing and metal geared
However, I do like the idea of having a bit more room and the ability to move the servo closer to the midline of the car with a micro servo. The problem with the digital (Im ONLY looking for digital) micro servos is they are either not fast enough (I want under .11 at 4.8V), or have questionable amounts of torque. That and of course I cant use the Xray Servo Saver (which rocks), and will have to custom mount it.
Here are the three I have come up with:
Futaba S3154 Digital Micro HT HS Servo
(4.8V)
Torque: 20 ounces
Speed: .10
-ball bearing??? plastic geared.
Hobby Electronics HDS-877
(4.8V)
Torque: 17 ounces
Speed: .11
-no idea. assuming no BB and Plastic.
KO Propo PDS-3014
(6.0V - NO ONE Has specs for it for 4.8V. Expecting .13 sec, and 24 torque)
Torque: 27.75 oz/in
Speed: .11 sec @ 60°
-ball bearing metal/plastic geared
(The Tekin specs for the micro they listed aren't that great speed wise, so its out of the running)
So, it sounds like the Futuba is the closest. I am just wondering if 20 ounces is enough torque for a sedan running on foams on carpet? I also then will need to find a good quality servo saver that will fit its output spline.
http://www.3drcracing.com/
oXYnary is offline   Reply With Quote
Old 12-18-2006, 07:00 PM   #2
Check out the following
Futaba 3101
Speed: .18sec/60 deg @ 4.8V - .14sec/60 deg @ 6V
Torque: 35 oz-in @ 4.8V - 43 oz-in @ 6V
2.5 kg-cm @ 4.8V - 3.1 kg-cm @ 6V
Length: 1.1" (28mm)
Width: 0.5" (13mm)
Height: 1.2" (30mm)
Weight: 0.6 ounce (17 grams)
Connector: "J" type with about 5" wire
or
Futaba 3102
Speed: 0.25 sec/60 deg @ 4.8V - .20 sec/60 deg @ 6V
Torque: 51 oz-in @ 4.8V - 64 oz-in @ 6V
3.7 kg-cm @ 4.8V - 4.6 kg-cm @ 6V
Length: 1.1" (28mm)
Width: 0.5" (13mm)
Height: 1.2" (30mm)
Weight: 0.7 oz (21g)
They are slower but don't let it fool you. The most dependable servos I have ever used in my micros. Onroad and offroad.
Bobby Z is offline   Reply With Quote
Old 12-18-2006, 07:29 PM   #3
oXYnary's Avatar
Bobby, those are waaay to slow, not digital, and not micro. (They are Mini size). I would suggest you try the Multiplex as then you could really see a difference and understand why I prefer faster speeds.
The ones I listed are about 24mm, and are micro/sub size.
I more interested in ounces of torque needs for 1/18th sedan as again the cut off whats acceptable torque. I have a friend using a KOpropo in his panther, and its just soo darn nice having all that extra room. I just think the KO propo is still too sloow for my needs.
Old 12-18-2006, 11:00 PM   #4
MikeR's Avatar
What about this? Specs are listed at 4.8v so it gets better with 6 cells.
http://www.b-p-p.com/proddetail.php?prod=c_hds_digital
www.exotekracing.com R18☆TEK18X☆TRF TA05R☆HB CYCLONE☆AE TC5☆HPI PRO4☆LOSI LXT☆M18 R3☆AE B44☆HPI CUP RACER
EXOTEK WILL BE CLOSED FOR VACATION 11/24 - 12/11
MikeR is offline   Reply With Quote
Old 12-19-2006, 04:06 AM   #5
oXYnary's Avatar
Mike, thats on the list above. The Futaba listed first is just as fast, but more torque.
Again, if I just get get an idea of what torque requirements are really needed for 1/18th on road.
Old 12-19-2006, 07:31 AM   #6
The speed and torque of the KO are more than sufficient. So anything compairable would be great. Plenty guys running it in 18t/b around here, and it will walk the truck off of a barrier.
duneland is offline   Reply With Quote
Old 12-19-2006, 07:55 AM   #7
Oxynary
Speed is nothing if you don't have the torque to keep the tires pointed in the right direction.
Maybe I will move some of my trophies around to make space on my shelf to park the Futaba servos to try something else one day!!!
Old 12-19-2006, 08:01 AM   #8
oXYnary's Avatar
Duneland, do you have a idea of what I would need torque wise though? I would rather get the Futaba since its .03 seconds faster (and cheaper). Have no idea of what its spline output it like though to match up to existing micro savers.
Bobby, I threw most of my trophies away as I don't have the space.
Besides, its all driving style. I'm used to not having as much delay before action/reaction. So my driving style has adapted that way. You have done the opposite.
I may just fall back on the Multiplex as its been proven. :/
Old 12-19-2006, 12:00 PM   #9
MikeR's Avatar
OOPS!
Well since you are now leaning towards the Polo here is another to compare. Not as fast but even more torque;
http://integy.automated-shops.com/cg...17106559778.bc
For me speed is important of coarse but torque translates for me into durability. The more torque rating then hopefully the longer the servo will last. I prefer not to use a servo saver (just like in 1/10th scale) so that's my dilema.
You should pick up 2 kinds of servos and track test both- never know until you try
Old 12-20-2006, 04:19 PM   #10
oXYnary's Avatar
Ok, I think im going with the ko or the futaba as I would gain around 5-6mm of space behind the servo!
I know the KO is a safe bet. Im still wanting the futaba more since it is faster (and cheaper), but still worried about the torque needs.
If anyone knows this info.. The futaba has a 3.98 mm, 15 spline output shaft. Can anyone compare that with the current micro savers to tell me if that matches up any currently available?
Old 12-20-2006, 08:52 PM   #11
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
I know the HPI MRS4 servo saver has multiple spines so they fit just about every micro and cost hardly anything...
I know Xray does make a servo horn (no saver) that fits micro Futaba servos...but if you hit alot of barriers it might not be a good thing to try.
Hope that helps,
-Shookie <><
AE makes a pretty good servo saver for all brands as well.
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 12-20-2006, 09:11 PM   #12
oXYnary's Avatar
Hope that helps,
-Shookie <><
No, unfortunately the Futaba in question is smaller than the other Futaba servos. Its brand new on the market. I am sending them an email to see if by chance it still takes the larger size output spline (if so, then I have my servo).
BTW: Xray does offer a servo saver (best micro one there is IMO). Its just doesn't have spline matches for these smaller micro servos listed above.
(The associated servo saver sucks btw. Cheap plastic C clip that looses all precision. Im not sure the HPI has splines for these smaller outputs. I think duneland mentioned the Sportwerks Chaos is the best he could find for at least the KO).
Old 12-24-2006, 10:16 AM   #13
oXY... I have a couple of those Futaba servos in stock & have been checking around.. So far, I can't find a saver to fit.
Old 12-24-2006, 08:51 PM   #14
MikeR's Avatar
I'm using the GPM metal c ring option on my RC18T. A world of difference
Forum Jump
high torque starter box 1/8 onroad aussies1129 Australia For Sale/Trade 2 12-09-2008 11:22 PM
Servo Torque miniczar Electric On-Road 5 03-21-2006 05:16 PM
Servo torque requirements for onroad MightyTaco Nitro On-Road 3 01-15-2006 04:42 AM
WTB High Torque Servo Everton R/C Items: Wanted to Buy 2 05-20-2005 03:15 PM
servo torque and speed? xxxtracer32 Electric Off-Road 1 08-10-2003 07:07 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
