Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 12-18-2006, 12:24 PM   #1
teammidget lilB's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to teammidget lilB
Default need help which lead??????
Hello i just bought a dynamite lipo pack the pic is below does anyone know which is the charge lead is it the red or white lead?????
Bryan "Lil B" Ford
T.O.P. Racing USA - SMC Batteries - High Velocity Racing .com - RCiD - Upgrade - Publix
teammidget lilB is offline   Reply With Quote
Old 12-18-2006, 02:21 PM   #2
Bermbuster's Avatar
It is the red connector (black & red wire) the white connector hooks up to a balancer. Never use the white connector for charging.....
Bermbuster is offline   Reply With Quote
Old 12-23-2006, 04:07 PM   #3
Troy_Konitzer's Avatar
I got the same LiPo and have been having issues charging. I called Horizon Hobby and they told me the short leads are used for charging, but not all LiPo chargers use the circuitry inside the battery. They told me I can charge it with my ICE charger by using the longer leads, but neither of the leads will give me a full charge in the pack.
What am I doing wrong? Please advise, I don't want to ruin it or worse.
Thanks,
Troy
Just remember...........it's only a part number! They'll make MORE.
I'm a local hobby shops buyer.
Where's your money going to promote local racing?
Troy_Konitzer is offline   Reply With Quote
Old 12-23-2006, 04:29 PM   #4
Bermbuster's Avatar
what charger are you using?
Old 12-23-2006, 05:27 PM   #5
I'm using the Duratrax ICE Charger set to LiPo, 7.4v, 1900mah, charging at 1.8a with a temp cutoff at 112 degrees F (which it never gets to). Any ideas?
Old 12-23-2006, 06:21 PM   #6
Bermbuster's Avatar
use the red (HPI) connector with the ice......
The white plug has leads that go to each individual cell this works w a balancer to ensure each cell is being charged properly. Some balancers interface w a charger. I charge my lipos packs with the ice using the power leads (red conn) and I always get a full charge and the packs work awesome. Just remember lipo packs dont tolerate wrong settings......
when you say you dont get a full charge.....remember unless the lipo is drained to 6.0v you will not take a full charge.
Old 12-23-2006, 06:50 PM   #7
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
uhh dude....charging is balancing....u plug it into a balancer.it still charges
ProudSavageOwnr is offline   Reply With Quote
Old 12-23-2006, 07:19 PM   #8
Bermbuster's Avatar
no charging is charging.....monitoring the charge is balancing.....
Some chargers have balancers built in.......
read this and learn........
http://www.rcmodels.org/csm/lipoman.PDF
and dude....Merry Christmas........
Old 12-23-2006, 07:38 PM   #9
berm is very wise
slicvicpr87 is offline   Reply With Quote
Old 12-24-2006, 08:57 AM   #10
Thanks for the help. I also have a LiPo 7.4v 1500 Cellpro and have had no problems charging it with the red connector on the ICE. The Cellpro LiPo works great.
The 1900mah Dynamite LiPo just doesn't perform after charging. The charging time is only like 5 minutes, so it's apparently pretty "full" in capacity or it's false peaking. But when I put it in the car, it has no punch to it and the run only lasts a few minutes of poor performance using high kv brushless motors. I've tried C4 9200kv and a Mamba 8000kv motors thinking maybe it's the motor, but the same result. For reference, I'm using the Mamba 25 ESC.
I know of guys that can run three 5 minute races on one charge (they may have a different LiPo). Any ideas on why this is happening?
Troy
Old 12-24-2006, 09:12 AM   #11
Bermbuster's Avatar
Originally Posted by Troy_Konitzer
Thanks for the help. Any ideas on why this is happening?Troy
Your welcome. The Dynamite pack most likely will benefit from a balancer. I cant say for sure but one cell in the pack may be charged and the other is not....(imbalanced cells) Do you happen to know the C rating of the pack?
Lower C ratings 10 and below usually give poor performance with BL set ups.
Remember not all Lipos are rated for high discharge amps. 15c and above is what you need for the Mamba to come alive......
Forum Jump
KO FET choke lead??? Yeoy Electric Off-Road 1 09-09-2008 06:04 AM
Lead Length AcadDude MaxAmps Support Forum 3 04-08-2008 09:39 AM
Lipo-Lead glassdoctor Electric Off-Road 10 01-23-2008 08:57 AM
KO VFS 2000 PC lead Mad Mackem Australian Racing 6 05-03-2005 03:01 AM
what is the fet servo lead for?? vere513 Electric On-Road 7 11-10-2003 08:18 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
