Hi bro t9dragon... I've post the question in one18th, lol... I'll like to check with you on the conversion. When you fix the inferno ST arm set, the whole arm are extended, do you use back the stock tie-rod for the front and rear? Because those arm are longer, therefore the need of the tie-rod too. IF so, where do you get them? Thanks..
