Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-23-2006, 09:09 PM   #1
blackdog's Avatar
Default 1100 mah nimh charging
all
Just got a used Mini T I have the 2 hour charger but just wondering what to charge the battery at with my Novak Millenium charger .
Thanks in advance
Matt
blackdog is offline   Reply With Quote
Old 11-23-2006, 09:25 PM   #2
shift's Avatar
Charge them at about 2amps
shift is offline   Reply With Quote
Old 11-23-2006, 09:56 PM   #3
blackdog's Avatar
Thumbs up Mini T
Matt
Old 11-23-2006, 10:45 PM   #4
Super Moderator
Grizzbob's Avatar
Just to add a bit to that, use the NiCd Linear charge mode & set the voltage threshold to 5mV(to start, try that setting & see how the cells feel after they peak, if they seem a bit warm, then try a step smaller threshold). That's how I charge my micro packs(I also have an original Millenium & a Millenium Pro, the non-Pro is what I typically use for the micro packs & for my transmitter batteries, works quite well)....
Go Pokes!!
Grizzbob is offline   Reply With Quote
Old 11-28-2006, 05:28 PM   #5
redhatman's Avatar
Send a message via AIM to redhatman Send a message via MSN to redhatman Send a message via Yahoo to redhatman
A good rule of thumb to go by is the mah of the pack. 1100 mah would be 1.1 amps, 1000 mah would be 1 amp, 1500 mah = 1.5 amps, ect.
You can do 2 amps but the stock pack isnt that good and it would make it fairly hot.
redhatman is offline   Reply With Quote
Old 12-25-2006, 08:48 PM   #6
blackdog's Avatar
Default Hay
Matt
Old 12-26-2006, 06:26 AM   #7
Bermbuster's Avatar
To take that info one step further....1100mah pack 1.1 amps also =1c.
Charging nimh you really dont want to go above 2c or 2.2 amps.
Charging at 1.1amp will take about 60 min (totally discharged pack)
Bermbuster is offline   Reply With Quote
Forum Jump
recharge on nimh 1100 battery question atebit Rookie Zone 6 06-14-2007 06:32 PM
M11 charging- AA NiMh D Hunt 3 Electric On-Road 12 12-26-2006 06:17 PM
Need help with charging AA NIMH MrRolla Australian Racing 7 09-26-2004 03:45 AM
Charging Nimh??? Lerlo Electric On-Road 1 04-12-2003 11:08 AM
nimh 1100 ma battery charging ? carpet_killa Nitro On-Road 1 02-09-2002 07:25 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
