mini lst
mini lst
Just picked one up, Any suggestions or issues I should know about?
The steering tie-rod will eventually have play in it so your steering will be a bit off, you can find the revised tie-rod on eBay, or just get the whole assembly in aluminum from 3Racing.
Turnbuckle ball cups will tend to pop off occasionally, some people got away with it by using a smaller ballcup end.
probably others have said......
servo's suck buy sets of rebuild gears or replace with jr241mg
buy servo saver aftermarket.....3racing
titanium or more affordable aluminum turnbuckles
if running any type of brushless set up shim pinions in fr/rr or replace with driven production pinions 6.95 a piece or gpm pinions 2.95 a piece
upgrade to deans plugs obviously or it WILL catch on fire
IB1400 6 cell packs work good on brushed applications
I just couldnt resist heres mine i just finished most of....
hope that helps
http://i79.photobucket.com/albums/j1.../rccars003.jpg
http://i79.photobucket.com/albums/j1.../rccars009.jpg
hope that helps
