Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 12-25-2007, 05:34 PM   #571
Default aluminumknuckles and arms
I have ordered the aluminm knuckles and will post wether they remove the play from the front axles. However, there is stil the problem of the front kingpins (steering axles). If you insert a king pin into the plastic bushing in the knuckle, you can see that it has a lot of play. This is not good. The knuckle should slide freely on the kingpin but it should not wobble. That's with the kingpin right out of the pack. In order for the knuckle to have the smooth movement it's supposed to have it should be polished. Polishing the factory kingpins would make them a little smaller in diametr hence giving you even more play. I'm hoping some aftermarket company will step up to the plate and make more precise knuckles, kingpins, and bushings.
oldrcer is offline   Reply With Quote
Old 12-26-2007, 12:15 PM   #572
Default front end parts
My Robitronic aluminum knuckles came today and guess what. One of the knuckles is pretty tight whlie the other is loose. Definitely not worth the $37.99 + shipping I paid. No wonder the BRP boys keep making fun of the Scalpel. Come on Robitonic...GET IT TOGETHER!!!!
Old 12-26-2007, 03:19 PM   #573
Do the aluminum arms have 4 degrees caster drilled in them?
bmcallister is offline   Reply With Quote
Old 12-26-2007, 05:42 PM   #574
I can't speak about the aluminum A-arms. I didn't get any of those...just the steering knuckles. I will probably just wait for Exotek or somebody to come out with some GOOD parts for it. You just can't go wrong with Exotek parts!
Old 12-28-2007, 11:57 AM   #575
ghiro's Avatar
Originally Posted by ghiro View Post
hi guys,i'm gaving an rx trouble.I'm using a ko kr301f fm27mhz rx,opened the case and shrink wrapped the whole thing,but i'm not so happy about it cause of the size and the conectors and crystal touches the body.Besides spectrum,do you know if theres a micro rx in 27fm band i could use?
. . . mmh guess nobody is using 27Fm band . . .
ghiro is offline   Reply With Quote
Old 12-28-2007, 01:22 PM   #576
Scottrik's Avatar
Trader Rating: 163 (100%+)
I was going to refer you to the GWS Pico receiver sold through Bane Bots but I see it is only available in 75 band. You may be crap out of luck other than what you've done.
"Team" Terribles...wtf???!!!...could ANYTHING be closer to a diet crouton?
President, Magic City RC...see us at http://www.magiccityrc.com
Proud member of ROAR # 11-10690 and One of the Region 11 seventeen (we know who we are!!)
RITCHIE REYNOLDS FOR REGION 11 DIRECTOR!!!
Scottrik is offline   Reply With Quote
Old 12-28-2007, 02:03 PM   #577
ghiro's Avatar
Angry
thanks,look like i've to buy a fm40mhz ko module and get a schulze micro rx or similar . . . thats gonna cost me more than a scalpel kit (95usd on stormer)
Old 12-28-2007, 02:21 PM   #578
Scottrik's Avatar
I wouldn't buy anything 40mHz unless I KNEW it wouldn't be used in organized competition. 40mHz is illegal here in the 'states.
Some thoughts...
Is a 75mHz module available? If so, the Pico receivers are on sale for a whopping $14 each plus $6-7 for the crystal. Even if you only popped the module in to run your Scalpel that'd be ok.
Have you considered upgrading to Spektrum? I finally stepped up last spring and haven't been sorry. The Spektrum micro receiver (3500) is PERFECT for the Scalpels and is available all the time on the fs board for $75 or so.
Old 12-28-2007, 03:31 PM   #579
MikeR's Avatar
If you can find a Novak XXL they made them as a universal 27band micro receiver in the past. I think they are now discontinued but try emailing novak to see if they have anything on hand.
I will vouch for the Spektrum 3500 also- perfect fit.
www.exotekracing.com R18☆TEK18X☆TRF TA05R☆HB CYCLONE☆AE TC5☆HPI PRO4☆LOSI LXT☆M18 R3☆AE B44☆HPI CUP RACER
EXOTEK WILL BE CLOSED FOR VACATION 11/24 - 12/11
MikeR is offline   Reply With Quote
Old 12-29-2007, 05:38 PM   #580
ghiro's Avatar
spektrum is certainly the way to go,but its very expensive(module +1rx are 200eu's=280bucks! with one rx,i need other 3 rx's)75mhz is outlaw over here,nobody realy cares but xtals and rx's are harder to find than 27mhz though,don't even know if and were to get a module for an "old" ko marsR !
Old 12-29-2007, 07:56 PM   #581
Scottrik's Avatar
Ah...hadn't realized you aren't in the 'states. 40mHz is probably fine then.
As far as prices, as strong as the Euro is against the dollar I'd be inclined to see what your "delivered" price would be from Stormer. They do a lot of overseas shipping so I'm sure they won't soak you on P + P. The $180 Spektrum Pro module plus receiver calculates to 122-123 Euro, I'd be delivered you'd be under 150. Probably closer to $140. In fact you'd probably have your module/rx plus two additional RX's and STILL be under 250E.
Just a thought if that had been an avenue you were considering. May as well take advantage of the weak dollar.
Old 12-30-2007, 12:56 AM   #582
stefan's Avatar
Send a message via AIM to stefan
Hi Ghiro,
where do you live? I moved back from the States a few years ago and I still have a 75 MHz module for the Mars, 3 receivers (2 Ko 301 and one Novak XXL) and a few sets of crystals.
I used those for a while and it is like using Spektrum
If you are interested, I'll make you a good deal. Let me know
stefan is offline   Reply With Quote
Old 12-30-2007, 10:06 AM   #583
ghiro's Avatar
Thumbs up
i've made a research on Stormer,after all i think Scottrik's wright,the value over the 2'nd rx is unbeatable.I think i'll keep the 27Fm for the M2Impact and use Spektrum for both,mini-t pro and Scalpel.
Old 12-30-2007, 01:59 PM   #584
What size are you guys cutting the tires down to? I noticed while putting my kit togther that the fronts is quite a bit smaller than than the rears. Is this normal for onroad cars? Or do they need to be the same size?
Old 12-31-2007, 04:20 AM   #585
stefan's Avatar
On a 2wd car like the scalpel, the tire diameter front to rear does not matter. The Xray M18 on the other hand is very sensitive to that.
I don't cut the tires at all, I think they are perfectly sized as they come.
Forum Jump
robitronics scalpel m18xray R/C Items: For Sale/Trade 13 09-19-2008 03:12 PM
1/18th Robitronics Scalpel NEW! arisking R/C Items: For Sale/Trade 8 03-09-2008 11:17 PM
FS: Robitronics Scalpel............... t9dragon R/C Items: For Sale/Trade 2 02-21-2008 12:40 PM
1/18th Robitronics Scalpel for trades Alain Patry R/C Items: For Sale/Trade 3 09-03-2007 05:14 PM
Robitronics Scalpel?? nitroracer20 Micro and Mini Scales 2 02-01-2007 04:08 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
