I'm using a Mamba as well w/ the 6800 motor. Pretty smooth response so far. Will only cog when the battery starts to dump. The Mamba motors will fit the stock motor mount as well
I have a scalpel and the front tires wear very fast. Does anyone have a brp and a scalpel to compare the front tire diameter? A Brp tire may be able to be modded onto a scalpel bearing and hub.
Wow, byron.s, those look really sweet! Whoever thought of that retro-styled, John Andretti inspired Miller body must be a genius! Your painting skills are, as they say, "hot and on fire!"
Ghetto Fabulous Racing: Not just ghetto, Ghetto Fabulous.
Team TYCO Jam Car: Independently controlled - acts as a moving obstacle!
i have been running my scalpel on carpet and it runs awesome the tire i have been using are super soft in the rear and soft in the front w/ everything else stock i sause the tires w/ paragon full rear half front but it seems like the car needs a lil more corner speed on exit what should i do
thanks for any input bryan
Bryan "Lil B" Ford
T.O.P. Racing USA - SMC Batteries - High Velocity Racing .com - RCiD - Upgrade - Publix
Bryan....Here are a few ideas you can try, but just try one thing at a time.
(1) when the "optional parts are available" try using softer front suspension springs than the stock ones.
(2) tighten the spring on the rear pod shock
(3) tighten the dampening disks attached to the upper rear pod "dry"
(4) put a small amount of heavy dampening lube between the dampening disks
(5) with any of these combinations, try medium front tires
(6) play with the ride height
(7) approach corners wider (larger radius)
Let me know which one of these ideas work. I have a scalpel too and would be interested to hear which idea works best for you.
