Anyone out there wanting to make parts for this car, a motor pod that will allow more adjustment in the ride height. With the highest setting you can only wear about half the tire. I am at 3mm with half my tire left, seems to me I will run out of ride height before tire.
Just checked mine- seems my rims could hit the ground and that I have plenty of room to 'scrape the chassis' Sure you have the right spacers?
I just ordered my car a few days ago. It was between the Scalpel and the M18Pro, hopefully I made the right choice.
My question is on the stock tires. It sounds like you all are using traction compound, and alot of it on the front. Our track is a relatively new RCP foam set-up, and they are not allowing the use of any traction compound. What has everyone's experience been running the tires "dry"? Will it work, what can I expect, and since this is the case, should I get that M18Pro on order as well?
I have ran the M18 not the pro but I am convinced there is no comparison. Two different cars totally. The Scalpel is just more fun to drive and reacts so much quicker. Think you made the right choice. As far as tires, we run on ozite carpet so I am not familiar with what you will be running on.
mine is in the works. hope it will cut in a few weeks.
PHAT QUAD RACING, TEAM LOSI, CRC, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS,PROMATCH RACING, TEAM BROOD, PARMA. www.browneng.org, TEAM SCREAM. ROBITRONICS, RC AMERICA, JOHN'S BSR RACING TIRES, SKYROCKET BATTERIES, TEKIN
