Micro RS4 servo saver works well for Micro servos but if you get a sub-micro (like I did, something the size of the KO PDS-3014) you'll need to find something else.
Ghetto Fabulous Racing: Not just ghetto, Ghetto Fabulous.
Team TYCO Jam Car: Independently controlled - acts as a moving obstacle!
Something went south in my KO, so I switched to the Airtronics 94091z.
Still using the Chaos saver on it. I cut the end off one of the kit horns for attachment of the tie-rods.
Just wanted to let people know that I have more Scalpels in stock today, and I know everyone is looking for tires, so today or tomorrow I will have my shipment of tires come in. I will post as soon as they come on because it will be a limited amount.
Anyone out there wanting to make parts for this car, a motor pod that will allow more adjustment in the ride height. With the highest setting you can only wear about half the tire. I am at 3mm with half my tire left, seems to me I will run out of ride height before tire.
I have ran my car quite few times all ready and the tires in front are G O N E. Luckily I ordered a set from STICKS. They are on the way WOO HOO. Hopefully him and Stormer Hobbies gets the other compounds in soon I will grab those ASAP. The car with the Mamba 8000 is F A S T pushes a lot without traction compound but I double sauced the fronts and just sauced the rears once and the car turns pretty good also the HPI Micro RS4 Servo Saver works very good had an encounter with a corner and my servo was saved. I also noticed when I put the servo saver it there is pretty much no clearance between the chassis and the saver but it does not bind up and affect the steering. The car still tracks straight and true.
Hey everyone just wanted to let you know the Scalepel kits, Front and Rear Foam Tires that come with the kit are in stock. Click on this link to order from the site http://teamscreamracing.com/catagory.php?type=GP3300
Also have the 4 Cell Matched IB 1400 Packs for this car ready in 1.16 to 1.19 voltages
