Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-03-2006, 10:45 PM   #1
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
Default Difference RC18T and RC18B HELP! URGENT!
ok guys i decided i wana get a rc18 but which 1?......is the rc18t just a version with bigger tyres and different body? or has it got diff shock towers,diff chassis,diff arms etcc........
PLEASE help me out on this and please tell me wat i should look out for when using brushless...like diffs blowing up etc
o and i wana get the factory team kit in either one so yeah..mabe that helps
ProudSavageOwnr is offline   Reply With Quote
Old 10-03-2006, 11:05 PM   #2
Bermbuster's Avatar
the rc18b uses different shock towers,wing mount,tires/wheels and body.
The top plate was different on early models of the rc18s but i believe they are the same now(newer one has buggy body mount molded onto it)
Just remember there is not a lot of room under the buggy body...you need micro electronics........
The FT kits come with really good hop ups. You will want to replace the aluminum dog bones with the MIP cvds....$20us per pair....
I told you the rc18s are durable and squirrelly.....this is because the plastic is flexy.....the dogbones usually pop out after a hard crash(flexing) With luck you can find the bone and the little spring.....(main reason for using cvds)
Next you need to tighten up the steering.....DP draglink and a small oring on the servo saver does the trick. I forgot to mention one more hop up....a front bumper. Get either the rpm or a tbone.......
Start from there and see what else you will need. Most likely not much.
Bermbuster is offline   Reply With Quote
Old 10-03-2006, 11:36 PM   #3
im guess the dogbones pop out because the outdrives are plastic right?
well im gona be putting some 5/16 pressure fittings on like they have done on www.beatyourtruck.com with their rc18b and my electrics are fairly small...
is the B any faster than the T? im guessing it might be?
and if i do get either wat should be the gearing? im gona be using 11.1v lipo wtih 5400kv motor
Old 10-03-2006, 11:56 PM   #4
Bermbuster's Avatar
the bones pop from the flex in the plastic chassis/top plate(makes the vehicle durable....some people love it some hate it) When plastic is made hard or cannot flex it usually breaks under hard impact. If the flex hampers your style get the diggity cf top plate and or chassis....DP is releasing a chassis very soon as well. Others make stiffer chassis as well.
new FT kits come with the outdrive sleeves.....
Try 60/14......check your temps....
Old 10-04-2006, 01:59 AM   #5
i got a 15tooth golden horizons pinion that i bought for my mini t.....will that work?
and wat dogbones r u talking bout? i dont see how the top plate or chassis flexing will cause the dogbones to pop out
Old 10-04-2006, 01:31 PM   #6
Bermbuster's Avatar
you get 3 pinions with the FT kit.....15t maybe too large....
if the chassis flexes the outdrive moves and the space between the outdrive and axle cup become greater than the length of the dogbone so it falls out.....this happens during a crash......not under normal running conditions....
Old 10-04-2006, 02:19 PM   #7
HotrodHopkins's Avatar
Trader Rating: 30 (100%+)
Send a message via AIM to HotrodHopkins
the 18B shouldn't be any faster than the 18T, they have the same gears, same motor, just a different body and wheels. I'd get the 18T so you can convert to the 18B or the 18MT
If you get the 18T, to convert to the b you will need the following...
Narrow Front Wheels; http://www2.towerhobbies.com/cgi-bin...?&I=LXLRA9&P=Z
Rear Wheels To Match; http://www2.towerhobbies.com/cgi-bin...?&I=LXLRB1&P=Z
Front Narrow Tires; http://www2.towerhobbies.com/cgi-bin...?&I=LXLRB3&P=Z
18B body; http://www2.towerhobbies.com/cgi-bin...?&I=LXLRB9&P=Z
wing mounts; http://www2.towerhobbies.com/cgi-bin...&I=LXLRA8&P=ML
18B shock tower set; http://www2.towerhobbies.com/cgi-bin...?&I=LXLRA7&P=7
and for the front body mount, just take a spare body post, drill a hole in the bottom and mount is straight up.
SHAUN HOPKINS a.k.a NoRod Hopkins
-1997 Dodge Ram 2500 Cummins 12v ECLB 4x4 5spd; 1990 Chevrolet K1500 Silverado TBI350.
-My lug nuts require more Torque than your Honda makes.
HotrodHopkins is offline   Reply With Quote
Old 10-04-2006, 11:48 PM   #8
so wat i belive is that the only things that are different are the wheels,tyres,shocktowers,body,wing
i got another Q......if i get the rc18t could i buy the buggy wing mount to make it look like a truggy?....like u can do with the mini inferno st...that accepts the inferno buggy wing mount...
and if im putting brushless in it...5400kv with 3 cell lipo....wat gearing and wat should i immediatly upgrade? im gona try prevent problems lol
also i have my mini t up for sale.....pm me if ne1 is intersted....also my savage is for sale too lol
Old 10-05-2006, 03:22 AM   #9
yes, those are the only differences.
and no, the wing mount won't work on the 18T, but if you get the 18b rear tower the 18t body will fit on it with an extra hole.
Old 10-05-2006, 04:01 AM   #10
i thought the wing was 1 peice with the body??
can i please get a link to the shock tower and wing and wing mount..thanks
Old 10-05-2006, 04:57 AM   #11
Bermbuster's Avatar
the wing will mount on the T shock tower. You just need to trim the T body for it to work.
As far as bulletproofing the drivetrain.....get a bag of shims for the outdrives.
The FT kit comes with carbide diff balls....make sure your d rings are flat(hone them on a flat plate) and glue them to the outdrive. Use AE stealth grease when assembling the diffs and they will operate smooooth........Use the shims to take out the side play of the diff in its housing (usually 1 or 2 shims do this)
Old 10-05-2006, 05:05 AM   #12
wat does "hone" mean?
r u trying to say that i glue the d ring to the outdrive? which outdrive? ....im confused :S and for the shims wat size r they? and cant i use normal greasE?
Old 10-05-2006, 06:15 AM   #13
Bermbuster's Avatar
maybe you should go to www.competitionx.com and download the manual for the rc18t. This way you can familiarize yourself with the truck and its parts.
honing or lapping the d drings is easy. You get a flat surface and put a pc of fine sandpaper on it now rub the the d ring over the sandpaper. Try to use a figure 8 pattern (cloverleaf is even better) when rubbing.....this will hone the surface flat......
Normal grease is just that normal
....you want some slicker than snot stuff.....
Old 10-05-2006, 12:00 PM   #14
no, the 18B body is not molded with the wing.
and i already gave you the links to the wing mounts and shock towers.
Old 10-05-2006, 10:34 PM   #15
Thai3g_Eclipse's Avatar
C'mon folks, Team Asssociated has this on the front page of their website.
You will need Adobe Acrobat Reader to view it: http://download.teamassociated.com/pdf/convert_mini.pdf
Considering this is straight from Team Associated themselves, you can't go wrong.
E-Revo / Mini E-Revo VXL / TB-02
Thai3g_Eclipse is offline   Reply With Quote
Forum Jump
RC18B or RC18T vtracer R/C Items: Wanted to Buy 3 02-15-2008 01:02 PM
WTB RC18T/RC18B Currin R/C Items: Wanted to Buy 9 10-16-2007 05:17 AM
WTB RC18T or RC18B Currin R/C Items: Wanted to Buy 16 07-23-2007 01:24 AM
Robinson Racing pinions for mini rc18t URGENT ProudSavageOwnr Australia Wanted to Buy 2 12-22-2006 11:48 PM
Mini tyres?Upgrades? Rc18B help!! urgent ProudSavageOwnr Micro and Mini Scales 9 10-20-2006 11:13 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
