1/18 tire truer
#16
Originally Posted by Bermbuster
does that truer adjust (x axis) close enough to the wheel? Do you have to make a tool spacer or anything? Thanks for any and all info.
berm
berm
no, you don't.
#18
so the integy arbor is all we need? not the complete integy truer?link would be great..would be great to use this on my ofna 1/10 truer
EDIT...found these with the part #....which one will be needed?
Integy truer
C22306C
C22306B
C22306A
Integy truer
C22306C
C22306B
C22306A
#19
acsubie, use the touring car arbor.
C22306A
C22306A
#20
C22306A
C22306A
ok thanks for the tip ..will be ordering the arbor/adaptor
last question, my truer only cuts down to 40mm, i true my micro tires a little more than that, will the knob move the tires close enough to the cutting blade? which truer are you using?
#21
The knob for the Integy truer will not move the tire any closer.
The Integy truer will cut small enough. Don't know about others. I also have the large Hudy & it will not go small enough. Perhaps you can use a different cutter/blade or shim the cutter closer to tire?
