Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Old 03-30-2012, 07:52 PM   #1546
Originally Posted by rmdhawaii View Post
Thanks. Looks like I won't be ordering any of those.
I guess everyone converts over to the composite drive shafts with hex adapters and buys the pro wheels.
Thats what we're doing (minus the composite drive shafts). I hope they handle the same as the old slip on tires for us. We're driving on a very unusual surface for the RC world but after driving it on carpet and RCP I don't understand why people like it so much.
+ YouTube Video
That race got a little sloppy with me flipping over on the first lap! It was still a fun one.
www.harnoishobby.com
http://www.facebook.com/pages/Harnois-Racing/186782821416027
Fajita Dave is offline   Reply With Quote
Old 04-03-2012, 05:25 PM   #1547
Default m18 i want to use a savox 0257mg servo
anyone use this servo in the xray m18 if so what servo saver are you using? the spline gear is small need some info and where i can get a servo saver that would fit thanks
bigtee is offline   Reply With Quote
Old 04-03-2012, 05:34 PM   #1548
Mini_Me's Avatar
Which servo?
Are you saying the spline on the servo is smaller than the xray servo saver? If so, if you have a dremel, take one of the arms that came with your servo. Cut off the arm. Put the now "armless" servo arm into your dremel with a screw through the center hole locked into your dremel output. Slowly with sandpaper "lathe" away the plastic until it fits inside the xray servo saver without and adapters. Do a quick check to see if the servo goes in nicely (if too tight give another pass on the dremel).
When fit is good, carefully take some ca around the barrier of the xray servo saver and the adapter you made. Let dry and your done.
*Have a question on the M18/T line of vehicles? Check the (unofficial) FAQ.
http://forum.teamxray.com/viewtopic.php?t=2524
*Need help finding an Xray supplier? Check the dealer/distributor database.
http://www.teamxray.com/teamxray/other/worldwide.php
Mini_Me is offline   Reply With Quote
Old 04-09-2012, 03:30 AM   #1549
JTM29's Avatar
Hey guys,
Havent touched my RC cars in a couple years and I want to get my M18 PRO running again. I am looking for some rubber tires as I go through the foam ones extremely fast of the surface outside my house. Rubber seems to last a lot longer on my 1/10th scale stuff.
I have the rims I just cant seem to find some rubbers. Does anyone know where i can get some, need to get them shipped to Australia.
Cheers.
JTM29 is offline   Reply With Quote
Old 04-09-2012, 08:03 AM   #1550
Default m18 racing video's from Holland
We drive once a month.
Carpet track, all cars stock 180 size motor and all 1600 mah LiFe 2s accu.
Great racing! Fastes lap time 10.3 seconds. We use LapZ for timing.
Have fun watching.
i'm not allowed to post a Url yet so you have to fill in the dots yourself.
"www youtube com/user/romulcorcshop"
Greetings,
Ed Veldman.
edjuh is offline   Reply With Quote
Old 05-02-2012, 03:55 PM   #1551
Poor man's asphalt semi-drift setup you may rotfl on this one, I don't mind
Why: to bash around outside the house, on asphalt, do some drifts but retain some control and be able to accelerate (pedal to the metal) without spinning. Very similar to driving on wet surface. Too bad the car is not waterproof.
How: start with a set of used medium foams (soft should also work). Add one layer of electrical insulating tape (pvc-like). Apply the tape without pulling - the foam should not be compressed. To be able to get the tape off when it wears, without destroing the foam, get some dirt/fibers onto the tape to make it stick only enough to stay on the wheels. I put it onto already dirty wheels (after an outside run with the foams), after I apply the tape several times onto my pants (free fibers).
If you have too much traction left, try with two layers of tape. Or harder foams.
The rear diff should be tight for (some) drift control. Also I have medium springs in back. Oversized bad-ass brushless motor preferred.
Don't forget to check that all wheels are touching the ground, adjust suspension if necessary (me rookie, forgot it the first time, than remembered a math lesson, the one that said that four points are not necessary coplanar).
danb1974 is offline   Reply With Quote
Old 05-23-2013, 02:44 PM   #1552
FL_SilverEvo8's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to FL_SilverEvo8
Anyone know where i can find step by step on how to mount these little rubber tires for this? They came with foam insterts but it doesn't wrap all the way around the tire. And am I post to stick them to the rim or the tire?
Off-Road - Durango:DEX210R(2wd Buggy), DESC210R(2wd SCT), DESC410R(4wd SCT)
On-Road - CRC: Gen-X 10 LE(WGT), X-Ray:T3 2011(VTA), X-Ray:T2 009(USGT) TRF 101(F-1), AE: RC10R5.1(Spec17.5)
Jeff's RC Studio Video>> http://www.youtube.com/watch?v=WtZ8-TV8Fs8&feature=share
FL_SilverEvo8 is offline   Reply With Quote
Old 05-23-2013, 02:44 PM   #1553
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
The adhesive foams go onto the wheels.
IIGQ4U is offline   Reply With Quote
Old 06-11-2013, 02:56 PM   #1554
anyone please tell me where to find 2.2mm screws, not sure why xray used this size.
if you have spare parts, like tires, please also let me know
looks like I entered this while everyone is leaving. the car is about to get disco.
thanks
NSLST is offline   Reply With Quote
Old 06-12-2013, 04:49 PM   #1555
Where did you get the information that they are getting discontinued????
Budman223 is offline   Reply With Quote
Old 02-06-2014, 10:03 AM   #1556
jannedwr's Avatar
Time to wake up the thread!
Next Saturday we are going to take away the jumps and usa our track as a touringtrack!
I took a look att my old M18Pro and painted a body for the event!
Mugen MBX7R ECO *Mugen MBX7R *X-Ray X12 2016 *X-rayM18Pro *Tekin*Sanwa Super Zero*Sanwa M12
Our tracks in Uppsala, Sweden
http://storvretarc.blogspot.com/
http://rorkenrc.blogspot.com/
jannedwr is offline   Reply With Quote
Old 02-07-2014, 06:44 PM   #1557
Originally Posted by Phil2112 View Post
Hey guys, does anyone have a m18 pro for sell? I have a older one and am looking to update it and start racing it again. I do have some other rc stuff that I'm willing to trade if the kit is in great shape.
Losi 22
MBX6 (tekno V4 Conversion)
MBX6 Nitro
AE 12r5.1 (rolling chassis w/ 2 bodies)
3pk w/aluminum case/ spektrum 2.4 modual and reciever
Let me know if anyone might be interested???
I have one that I'm not running right now. It doesn't have the lipo chassis though. It does have aluminum diffs, one way in front, aluminum hub carriers, aluminum driveshafts, atomic for both, steel pivot balls. The thing looks brand new, besides a few scratches on the bottom of the chassis. I'd love to get into a novak mongoose set up with the 8.5 or 10.5 turn if you have access to one of those.
Matthew p is offline   Reply With Quote
Old 02-08-2014, 08:46 AM   #1558
jannedwr's Avatar
Tested my M18 today on a small part of our buggy track, for the real track next weekend. What a great little flying car, everybody was stunned about the speed, braking and fast steering it has! It turns so quick you allmost cant follow it compared to a 1/16 buggy and flyes past on straights. Next weekend we gonna build the track for touring cars and thats when the real racing will be!
Old 05-31-2014, 10:46 PM   #1559
mugler's Avatar
SoCal Mini-Z Thread
FIRST SUNDAY OF THE MONTH MINI-Z TRACK DAY AT
BALDWIN PARK, CA.
NEXT OPEN PRACTICE TRACK DAY >> Saturday, 12/02 10:00 to 6:00
NEXT RACE DAY DEC 3RD, 2017.
mugler is offline   Reply With Quote
Old 06-04-2014, 01:03 PM   #1560
mugler's Avatar
Anyone interested in Xray M18 roller with very nice racing hop ups send me a pm or email me.
Cheers,
SoCal Mini-Z Thread
BALDWIN PARK, CA.
