Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 12-27-2008, 11:21 PM   #241
jcr
Originally Posted by Dark_gouki View Post
hard on rear soft on front, they grip really good and they last twice as long as the orion fresh kicks, and the hpi ones, i still gotta get the GQ foams though.
Really? Hard on the rear and soft in the front?
jcr is offline   Reply With Quote
Old 12-28-2008, 02:37 PM   #242
rogueldr's Avatar
Please help. My front diff in my MRS4 is blown. I need a whole new diff not just the diff frame and I can't seem to find a complete diff anywhere. Does anyone have any idea where I can get me a whole new diff? Thanks
rogueldr is offline   Reply With Quote
Old 12-28-2008, 07:09 PM   #243
rogueldr's Avatar
Forget it I found 'em.
Old 01-04-2009, 09:41 AM   #244
k_bojar's Avatar
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
As long as I've been running the mRS4, I hate asking this newbie question...
but what is the difference between these 2 chassis:
HPI Chassis Micro RS4 (PN 72332) (http://www3.towerhobbies.com/cgi-bin...?&I=LXAYS5&P=Z)
and this one:
HPI Chassis Type B Micro RS4 (PN 72333) (http://www3.towerhobbies.com/cgi-bin...?&I=LXNYL1&P=Z)
I've run either a Ratzas or ExoTech chassis for so long, I didn't even know HPI did another stock chassis
Team Tekin | Bodies By Bean | Banzai Motors | ExoTek Racing | Team Belly
k_bojar is offline   Reply With Quote
Old 01-04-2009, 10:19 AM   #245
rogueldr's Avatar
I need help and I hope someone here can help me out. I recently installed a Penguin 3500 LM chassis in my MRS4 and replaced the belt along with it. I'm running a ball diff in the rear w/ a stock diff in the front (until I can get my hands on a one-way), team orion micro modified motor, w/ a Novak spy esc and a Team Orion 1600 6 cell pack. My problem comes while running. The car runs fine for a few seconds then seems to bind up and freeze. When I pick it up and put it on the bench while its bound up the rear wheels will spin nice and free but the fronts seem to be locked up. I though it was the front diff so I pulled it apart and inspected it. The plastic gears seemed all right except for one tooth that seemed nicked. After reassembly the car rolled smooth as glass. Then once I put the motor back in and put power to it the same thing happened. I just placed an order for new gears and I hoping that will do it. Anyone have any other ideas? Plus does anyone know where I can get a front one way for this little guy. I need to get this thing running because all of the M18 and RC18 guys at my local track talk a lot of smack and I need to show them what my little HPI can do. Also is there a way to put some tension on the belt? I have the chassis set to 150 w/ a 150 belt but it is real loose and I think part of the problem is the belt slipping off of the front spool.
Old 01-04-2009, 11:58 AM   #246
k_bojar's Avatar
Did you check the rear-end of you car?? It kind of sounds like your rear is too tight...there should be some play (side-to-side) in the rear axel...this will help with the play in the car some...
also if you over tighten the rear wheels to tight, the car will bind - you need to tighten the rear wheels until they are snug against the inner hubs, not super tight...
I'd check there first, then move to the gear mesh...If that's too tight, you'll bind as well...you will need to adjust the gear mesh - there's all kinds of theories about the best way to set up gear mesh, so pick you favorite
I normally slide the pinion into the spur, then back it off so that I can freely rock the spur gear in the pinion - not super loose, just enough to rock a little...
try looking there and see what happens...
Old 01-04-2009, 12:06 PM   #247
Super Moderator
Grizzbob's Avatar
and this one:
Looks to me like the "B" chassis was meant for the Drift version of the car, & according to the Tower listings, the "B" version is a couple of mm longer(180mm vs. 178mm) & uses thinner material(1.78mm thick for the "B" version vs. 2mm for the original), so the "B" version might make the car a tick longer(but not sure on that) & should flex more than the original....
Go Pokes!!
Grizzbob is offline   Reply With Quote
Old 01-04-2009, 02:32 PM   #248
rogueldr's Avatar
Did you check the rear-end of you car?? It kind of sounds like your rear is too tight...there should be some play (side-to-side) in the rear axel...this will help with the play in the car some......
I've checked the rear of the car and it seems fine. When the car is binding it's the fronts that seem to be stuck because the back spins freely. I also noticed that the belt seems to come off of the front pulley when its bound up. I'm thinking that could be the problem also which leads me to the question of tightening up the belt. The chassis is set at 150 and its a 150 belt but it seems real loose and I have no idea how to tighten it.
Old 01-05-2009, 08:34 AM   #249
jcr
I got a Micro RS4 with the Exotek EXO-150 chassis. Everything is running great but I get traction roll once in a while when I make a hard right (hairpin turn). I'm running soft tires in the rear and I think hard in the front. Any suggestions on eliminating the traction roll?
Comparing Team Orion's Big Block to the Micro Modified, which one is fast or better overall? Any other motor suggestion without going to brushless?
Old 01-06-2009, 09:59 AM   #250
Ed Anderson's Avatar
Trader Rating: 18 (100%+)
and this one:
Hey Kbo,
Like Grizz said, the type "B" chassis came with the drift version cars... it also came with the ARR cars (assembled but no electronics... exc motor). Its the same lenght as the original and can be ran 140mm or 150mm.
Without them here in front of me... one could be thicker than the other. Difference I can see is the cutout has a different shape. One is longer front to back and norrower. The other is shorter and fatter. So basically the rear frame rails are wider on one.
I've ran them both... and can't say I notice any difference.
One thing I noticed on replacements is... on the original "versions" the screw holes arn't counter sunk enough... and the screws stick out. The type "B", they are fine.
Ed Anderson is offline   Reply With Quote
Old 01-06-2009, 10:58 AM   #251
Dark_gouki's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dark_gouki Send a message via Yahoo to Dark_gouki Send a message via Skype™ to Dark_gouki
the binding will happen if the belt slips off the front pulley, to fix that i bought the alloy pulley for the front,. also on the old 1:18th.com site some guy made a mod for a belt tenisoner, but the site is gone so i doubt you would ever find it. CHECK yourmicro.com go to the micro rs4 mods section might be sumtin in there.
My Nitro Assassins
S2D= Novak 8.5T
M18= Tekin 9200kv
All My Whips Are SBD (Silent But Deadly)
Dark_gouki is offline   Reply With Quote
Old 01-06-2009, 11:01 AM   #252
Dark_gouki's Avatar
The Graupner Speed 300 6v, this is the same exact motor as the team orion big block without the hefty price tag. BTW between the motors u have above the big block is better i know because i own them both in addition to the Speed 300 6v
My Nitro Assassins
S2D= Novak 8.5T
M18= Tekin 9200kv
Old 01-06-2009, 11:27 AM   #253
jcr
Well I see the Big Block fairly cheap now, like $13. How much is the Speed 300?
no one having traction roll problem? How to solve this (it's not like my 1/10 which I can do more adjustments).
Old 01-06-2009, 11:40 AM   #254
Dark_gouki's Avatar
OH snap if the big block is $13 go get that cause the speed 300 6v is $13.90
My Nitro Assassins
S2D= Novak 8.5T
M18= Tekin 9200kv
Old 01-06-2009, 11:43 AM   #255
Dark_gouki's Avatar
As far as traction roll i just threw a vcs shock on the rear and added the gpm front shocks, also put a little CA glue on the sidewall of your tires if your running foams.
My Nitro Assassins
S2D= Novak 8.5T
M18= Tekin 9200kv
Forum Jump
Official Micro Championship (onroad & offroad) THREAD maximebeauvais Micro and Mini Scales 46 10-12-2009 06:48 PM
Micro-T thread!! colt1402 Singapore R/C Racers 7 11-02-2007 09:28 AM
Calgary Mini/Micro Thread BuddhaTech Canadian R/C Scene 62 08-03-2006 12:59 AM
Indy Micro Racing Thread BadSign Micro and Mini Scales 1 07-15-2006 03:57 PM
Mini and Micro thread. losi International Racing Team 147 11-11-2004 06:17 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
