Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-16-2008, 09:32 PM   #211
geeunit1014's Avatar
Originally Posted by Dark_gouki View Post
Also Where can i buy The GQ Orange Micro Wheels.
http://competiton-rc.com
Mike Gee
Team Driver For: Exotek/Castle/Psycho Cells/GQ Tires/Darkside Designz/Rad Racing
Proud Supporter of: MRL (Micro Racing League) / Final Thoughts RC Club
geeunit1014 is offline   Reply With Quote
Old 10-16-2008, 09:55 PM   #212
Rapid Roy's Avatar
Originally Posted by Paperman 90 View Post
I just got mamba 25 4200kv and im going to put in my micro rs4 with a venom 2s lipo 1250mah pack do any one have any ideal how fast will go.
It will go plenty fast. You just need to gear it properly. Start with a small pinion. 9 or 10 tooth should be a good start.
Rapid Roy is offline   Reply With Quote
Old 10-18-2008, 12:51 PM   #213
Dark_gouki's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dark_gouki Send a message via Yahoo to Dark_gouki Send a message via Skype™ to Dark_gouki
Originally Posted by geeunit1014 View Post
the site is not up anymore.
Dark_gouki is offline   Reply With Quote
Old 10-18-2008, 05:18 PM   #214
Dark_gouki's Avatar
Well due to my penguin el chassis broke i had to switch to my alloy chassis check it out.
Old 10-18-2008, 05:21 PM   #215
Dark_gouki's Avatar
I got A question also What body posts fit the hardcore racing rear deck because i have the the hpi normal ones and the gpm alloy version of the hpi ones and the holes are to big. Any help guys.
Old 10-20-2008, 07:22 PM   #216
sorry, the www makes a big diff. heres a straight link GQ's
Mike Gee
Old 10-20-2008, 08:23 PM   #217
Rapid Roy's Avatar
There should be a plastic insert/sleeve that goes into each hole in the rear deck. I'm not sure where you can get those by themselfs. You can try buying a cheap graphite deck on ebay that comes with them. Maybe hardcore still has them available. I'm not sure if hardcore is even around still.
Old 10-20-2008, 08:31 PM   #218
k_bojar's Avatar
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Roy - were you ever able to find another source of lipo batteries for the exo3??
I had a cell take a dump after the NJ Challenge in July :x and that was an adventure finding the apogee pack I did run...
if you want, you can post it here or shoot me an email
thanks
kaybo
Team Tekin | Bodies By Bean | Banzai Motors | ExoTek Racing | Team Belly
k_bojar is offline   Reply With Quote
Old 10-20-2008, 08:45 PM   #219
Rapid Roy's Avatar
thanks
kaybo
I thought I posted the link where I got my lipo here, but it was on the now defunct one18th.com and lost now. I'll poke around and see if I can find the receipt.
Old 10-20-2008, 08:49 PM   #220
Rapid Roy's Avatar
Was this the one? If so, apogee has them in stock. I can't remember so good. Everything is put away right now and not easily accessable
http://pfmdistribution.com/secure/sh...d=239&catid=59
Old 10-23-2008, 11:05 AM   #221
Rapid Roy's Avatar
Originally Posted by harry2008 View Post
Hobby Products International or HPI of Foothill Ranch, California, USA is a manufacturer of on- and off-road radio-controlled cars, both electric and nitromethane powered. In 2005 HPI merged with Hot Bodies, another company owned by Mr. Watanabe, which initially began manufacturing bodies and upgrade parts for the HPI RS4 Pro 3.Today, they produce a wide range of radio control cars, trucks and buggies, plus accessories. Many of the plastic suspension pieces for the Hot Bodies Cyclone, their top-level electric touring car, come from HPI's Pro 4.
Harry
Our mission is to provide high quality end to end solutions to the BPO segment in a manner that will improve the operational efficiency while reducing the cost of the services to the client.
4thdimension1@gmail.com
Do you work for HPI? Is there a reason you felt the need to share this information with us? I'm pretty sure most of us has read that snippet from the HPI web site since we all own a HPI product.
Old 10-25-2008, 11:48 PM   #222
STR_17's Avatar
I got a quick question for you guys.
I just recieved a box full of MRS4 parts and a few complete rolling chassis that I am going to build into a spec fleet to race at my local track-stock crappy motor, and a mediocre 5 cell pack.
In the big box of stuff, I got a couple of the stock RTR "pro control" esc's but I noticed that they dont have a one toch button or anything like that
is there some way to set these things up to a new radio or are they just supposed to work the way they are?
"Hey, thats racing"
on the car:
Kelowna Speedway and Hobby
High Octane Hobbies
T-BANG!
www.rcmtracer.com
STR_17 is offline   Reply With Quote
Old 10-26-2008, 01:44 PM   #223
Dark_gouki's Avatar
Thumbs up
Those Esc's are just plug and play. Just plug it up and turn it on and off you go.
Old 11-19-2008, 06:15 PM   #224
ChadRacing's Avatar
what do you have to do to mount Xray M18 wheels to a MRS4 car? I am tired of having my wheels slide off so i want to be able to use a nut liek the xrays do. Can someone please help me...
TEAM HIGH VELOCITY RACING
www.highvelocityracing.com
MLP Team Driver
NEXUS RACING
MLP Viper F1 Pro, Xray T2 '008 EU & '009 US SPEC, KYOSHO HOR, RC18B
ChadRacing is offline   Reply With Quote
Old 11-19-2008, 10:43 PM   #225
Rapid Roy's Avatar
Some people glue the wheels into the inner wheel. Then drill out the center of the outer wheel to get access to the nut. This works really well, but you need to buy lots of inner wheels and you can't switch wheels between the front and back.
I take a thin strip of lexan about 1/8" wide and loop it inside the outer wheel. Then I put the outer wheel on the inner wheel with ribs and slots miss aligned. This jambs the wheels together really tightly and the lexan strip keeps the wheel at a wide setting.
The x-ray pro wheel setup won't fit up without some modification. I'm really not sure if it can be done or not.
Forum Jump
Official Micro Championship (onroad & offroad) THREAD maximebeauvais Micro and Mini Scales 46 10-12-2009 06:48 PM
Micro-T thread!! colt1402 Singapore R/C Racers 7 11-02-2007 09:28 AM
Calgary Mini/Micro Thread BuddhaTech Canadian R/C Scene 62 08-03-2006 12:59 AM
Indy Micro Racing Thread BadSign Micro and Mini Scales 1 07-15-2006 03:57 PM
Mini and Micro thread. losi International Racing Team 147 11-11-2004 06:17 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
