Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 04-20-2008, 08:59 AM   #136
BigB11 YGPM
Kevin Colgan aka captmicro
The Captain
Backbreaker Racing
Team South Shore Hobby
Long Island Raceway-Slash #750
BackBreaker1 is offline   Reply With Quote
Old 04-27-2008, 10:43 PM   #137
Rapid Roy's Avatar
Hey, just wanted to post my race results today. I didn't get all my parts to get my EXO3 up and running, so I ran the trusty EXO1 with NMhi batteries and the fireball motor. The car was hooked up and the motor was ballistic. If finally figured out a tire/spring combo that was killer. Qualified 2nd behind Mike who was in another world. He cake walked using a 18T with his special chassis. I had great qualifiers and a good main going until my rear tires decided to partialy let go from the rims. They would baloon up at higher speeds and make the car turn suddenly right. Had lots of fun though.
Rapid Roy is offline   Reply With Quote
Old 05-06-2008, 09:02 AM   #138
MikeR's Avatar
Yes, your car was a rocket ship. Think faster than mine down the straight Was fun racing!
www.exotekracing.com R18☆TEK18X☆TRF TA05R☆HB CYCLONE☆AE TC5☆HPI PRO4☆LOSI LXT☆M18 R3☆AE B44☆HPI CUP RACER
EXOTEK WILL BE CLOSED FOR VACATION 11/24 - 12/11
MikeR is offline   Reply With Quote
Old 05-10-2008, 07:47 PM   #139
k_bojar's Avatar
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Mike - any chance of you posting a couple pics of your chassis WITH your electronics mounted?
I found a way to get the HS81MG in the 140mm chassis, now just trying to see how to run the wires
Kaybo
Team Tekin | Bodies By Bean | Banzai Motors | ExoTek Racing | Team Belly
k_bojar is offline   Reply With Quote
Old 05-10-2008, 08:50 PM   #140
SN33KY's Avatar
get the 82mg
the 81mg has centering issues
or you can go with the s3102mg from futaba, thats what i use on my m18
SN33KY is offline   Reply With Quote
Old 05-10-2008, 11:27 PM   #141
k_bojar's Avatar
Originally Posted by SN33KY View Post
get the 82mg
Funny, 99% of all the people I race with have a problem with the HS81 - I'VE NEVER HAD A PROBLEM WITH THE 5 or 6 of them I've had...I have 2 now, which are fine...sold a couple with my original M18
The issue I was having is that its a VERY tight fit with ANY servo and the lipo pack on the 140mm chassis - so it really don't matter what I used...I looked at the spec on the 82 - its the same size as the 81 and 85...Don't know the specs on the Futaba one, but I ain't dropping the $$ on one...
I've need using hitec micro servos in my cars since the mRS4 first came out - and don't really see a need to change now I actually ran some model futaba in my m18 - didn't like it, and switched back to the hitec...
Old 05-11-2008, 01:29 PM   #142
Rapid Roy's Avatar
Kaybo
I was just looking at the fitment of the battery too. Did you remove the shrink wrap or did you mount it up off the chassis with shims?
Old 05-11-2008, 08:26 PM   #143
k_bojar's Avatar
I didn't do anything with the pack yet...was thinking about removing the shrink sit it is a little big and I didn't feel like looking for shims
That's kinda why I wanted to see a pic or 2 of Mike's cars
Roy - do you have the 140 or 150 chassis?
Old 05-11-2008, 08:26 PM   #144
MikeR's Avatar
Kaybo
I would but I for the life of me cannot find my EXO3 roller. I'm afraid my 2 year old stuffed it somewhere in the shop From what I recall the battery wire faced forward and to the right of the servo if that helps, mamba on top of battery and micro spektrum left of the servo.
Old 05-11-2008, 08:31 PM   #145
k_bojar's Avatar
I was test fitting mine with the wires on the left side of the chassis (drivers side) with the spektrum receiver there as well....
I'm still waiting for the day my 2year old does something similar - luckily she's still a little afraid of them
Mike - any chance of coming up with another option for the side springs?? I tried ordering the HPI parts of they are all outta stock - even the like the Roy sent me..and over the years I've ditched most of these type extras
Old 05-11-2008, 08:51 PM   #146
MikeR's Avatar
Hmm maybe Golden Horizons? They used to make alloy dampers so maybe he has spares laying around his factory?... What about also Micro T shocks? pretty cheap and worth a shot.
Old 05-11-2008, 10:23 PM   #147
Rapid Roy's Avatar
I orderded and received that part from www.amainhobbies.com last week. Give them a try. RCboyz only sent me one. The part I just received was missing the extra shock shaft. Good thing I have an extra one from before. Now I can't find the 1st set I received from RCboyz.
Looking at my 140mm chassis, I was thinking that if I removed the servo mount and shoe gooed the servo to the chassis, I could slide the servo forward far enough for the battery to fit in there. I also have the 150mm chassis and will move everything over once I get all my parts.
I just checked amain and the part is in stock.
http://www.amainhobbies.com/product_...ducts_id/10167
Old 05-12-2008, 04:15 AM   #148
k_bojar's Avatar
amainhobbies has them in stock, hmmm....If they have 2 sets, I'll have to tell rcboyz NOT to back order them for me...
I've thought about shoe-gooing my servo in, but I like Mike's mounts and I got the servo to fit by removing the bottom part of the case - doing that gave me the extra space I needed
Just have to decide what I want to do about the wrap on the lipo pack
Old 05-12-2008, 08:49 AM   #149
Rapid Roy's Avatar
I ordered 2 from RCboyz. They only ended up having one. I ordered the second one from amain and got that one quick. Now I can't find the 1st one.
I'll eventually get this darn thing together and raced. I'm having a little bit of a delema though. Last race the EXO1 ran so well I want to run it again. I'm sure I can get the EXO3 to run at least as well. I got a some advise from another racer (I don't even know his name) that was commenting on my car/chasis. He used to run 1/12 pan at So Cal raceway and said they always ran the front as stiff as possible and the rear as soft as possible. I stiffened up the front and the car was on rails.
Old 05-12-2008, 10:04 AM   #150
k_bojar's Avatar
I normally run the kit black springs in the front, with a black AE spring in the rear...but when that kind of tip, i might consider running the green springs up front - but, like you parts, i can't find them now
Forum Jump
Official Micro Championship (onroad & offroad) THREAD maximebeauvais Micro and Mini Scales 46 10-12-2009 06:48 PM
Micro-T thread!! colt1402 Singapore R/C Racers 7 11-02-2007 09:28 AM
Calgary Mini/Micro Thread BuddhaTech Canadian R/C Scene 62 08-03-2006 12:59 AM
Indy Micro Racing Thread BadSign Micro and Mini Scales 1 07-15-2006 03:57 PM
Mini and Micro thread. losi International Racing Team 147 11-11-2004 06:17 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
