Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 03-09-2009, 06:24 PM   #1411
mlight13's Avatar
Hey all, what are some good off-road bashing tires for an RC18T? My stock mini-pins only lasted two weeks and I only use it on grass and dirt. I have some Pro-Line Road Rage's for street, so I thought the stock tires would last longer...but no. Thanks in advance...
mlight13 is offline   Reply With Quote
Old 03-10-2009, 12:53 AM   #1412
drperry's Avatar
Send a message via AIM to drperry Send a message via MSN to drperry Send a message via Yahoo to drperry
The stock tires for the 18MT wear like iron... Mine were run pretty much exclusively with the Mamba 6800, and other than being dirty, they still look pretty new...
They're not the best gripping tires in the world, but not the worst... At least, on dirt/grass/cement/pavement.
RC18MT - Tekin FX/Stock motor
Yokomo MR-4TC SD CM Novak GTB/LRP X-11 13.5 brushless
Kyosho STR(R) - RB TM728 (btw, I HATE pullstart! lol)
Traxxas Jato - Castle Creations Mamba Max 5700kV cog-o-matic
drperry is offline   Reply With Quote
Old 03-10-2009, 07:11 AM   #1413
Suspended
You might want to try some ProLine DirtHawgs for offroad bashing. Bowties give way better traction and wear longer than the stock pins.
http://www.prolineracing.com/c-46-tires.aspx
Lightin' is offline   Reply With Quote
Old 03-12-2009, 06:45 AM   #1414
Ok I am running my RC18B off road on an outdoor track for 1/10th. I was reading about bigger wheels and tires, Just so I get this right you use Kyosho Half 8 wheels and tires with 12mm hex adapters. Does this sound right. I just want to get the right stuff to do it.
All in is offline   Reply With Quote
Old 03-13-2009, 06:09 AM   #1415
are there narrow foam tires like what the 18b has on the frount of it and does anybody have a stronger wing mount for sale that fits the rc18t
rc 18t is offline   Reply With Quote
Old 03-13-2009, 05:20 PM   #1416
Default How to Slow Down an RC18MT?
This may seem like a silly question, since most people want to make their cars faster, But...
I really need to slow down my RC18MT a lot so that my kids can use it. Does anyone have any good suggestions?
I wonder if a 180 motor could be installed and if this would do the trick. Any thoughts or motor suggestions?
Other things I've tried that didn't work good enough:
-reduce the number of cells in the battery packs (lower voltage).
-adjust the throttle ATV on the transmitter
-tape up the trigger (works OK for forward, but not in reverse).
Thanks!
jimmyb223 is offline   Reply With Quote
Old 03-13-2009, 06:04 PM   #1417
drperry's Avatar
Adjust your throttle end points, if you can, otherwise get a 4 cell pack.
Old 03-13-2009, 06:53 PM   #1418
I actually tried a 4 cell pack and a 2 cell pack. There really isn't that much difference.
Old 03-14-2009, 04:34 PM   #1419
Hey I am also wondering what size on road bodies fit these is it the 150mm, I searched and found nothing
Old 03-14-2009, 07:25 PM   #1420
blackdog's Avatar
Thumbs up RC18T drivetrain issues???
Hi
I didn't know were to post so I posted here..
I just picked up a second hand rc18t last week .I installed my mamba 25 into it .the truck dog tracked and had no balls ??? (no go go).so i totally stripped it down and put two fresh diffs in .same thing happens lol.if you hold the truck in hand it seems fine but as soon as you put it on the floor it acts up .battery is full and I'm pretty sure the mamba is set properly.
any help would be great .PM me if you can help out..
thanks in advance
Matt
blackdog is offline   Reply With Quote
Old 03-14-2009, 08:01 PM   #1421
myrxseven's Avatar
The only bodies that fit the 18r is the replacment associated bodies, the Exotek GTZ body, and Rj Speed makes a couple muscle car bodies and a Stock car body. Also on The Toyz there is a Bentley and an old Corolla.
CRC Gen XL 17.5 1s Lipo
Spektrum l Novak l Tekin l SMC l Jaco
myrxseven is online now   Reply With Quote
Old 03-14-2009, 08:02 PM   #1422
myrxseven's Avatar
Originally Posted by blackdog View Post
Hi
thanks in advance
Matt
Try gearing down. Maybe its cogging?????
Old 03-14-2009, 08:11 PM   #1423
blackdog's Avatar
ok
I'll try that ,it is geared 18 pinion with a alum 54 spur .Im not totally sure if this 18 tooth is from 48 pitch stuff but it meshes real good .would this mess things up being 48 pitch.the truck does this weird jiggy jag right from turning it on .not much more I can say till I swap out the pinion .
Matt
Old 03-14-2009, 08:20 PM   #1424
drperry's Avatar
Stock gear pitch is 64...
Old 03-14-2009, 09:13 PM   #1425
blackdog's Avatar
Default rc18t drive train issue
I switched the pinion from a 18 to 14 and still the same out come ??? Im going to swap out the alum spur for a stock one ???? . would the shimming of the diffs play a big part .thanks guys for the help so far.
Matt
Forum Jump
** The Official HOT or NOT Thread *** JVT MTX3 Chat Lounge 2431 12-30-2007 04:19 PM
Official MT2 RTR Thread PowayLAX1 Electric Off-Road 18 03-20-2007 01:03 PM
LST Official Thread Whipple81 Monster Trucks 0 10-06-2004 10:30 AM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 03:09 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
