From what I can tell it lets the front tires free-spin off-throttle but when you get on the throttle the front "locks" and both front tires will have power. Gives it a ton of turn in and lotsa pull coming out of the turn. Like I said it allowed it to carry a ton of speed through the infield (smaller and sharper turns).
From MIP there is a spool and a one-way spool. I have the one-way spool, so I'm not sure what a "traditional" spool would do.
Yep it lets it run like a 2wd thru the corner and then pull like a 4wh anytime you are on throttle. Downsides are you lose braking from the front wheels and the rear can slide out if you hammer the brakes just like a 2wd.
The losi xx4 had a sweet clicker system. You could tighten or loosen the front one way effect with the turn of a nut. Was a pretty slick setup.
I won a 900 mah 15C lipo off ebay for under ten bucks. Dang thing is amazing in the little truck. Half the size of a nimh batt and more power. Haven't seen how long it's lasted yet b/c I only drive for a bit at a time in the basement. Will give it a time test sometime in the spring when the snow is gone.
I have a problem with my rc18r i think wen im racing or wen i pick up my car the arms move up and down like idk maybe i gota put a spacer! people who have rc18r would know wat im tlaking about its the front!
Uhh... like...huh...? Maybe you have a bent shock shaft.
That was painful, couldn't watch it.
So you will have to describe your problem in more detail.
Download the manual and you will probably be able to figure it out on your own.
Ty man i was looking for just that And its suppose to do that? i dont think so lol
Well it IS supposed to be sloppy like that, that's just part of it's flawed design. Now does that make i right? No, no it doesn't, but it is what it is.
Typing words out and not using run-on's will make your posts a lot easier to read. Just a suggestion, because I had NO clue what you were talking about at first
Novak - Tekin - XRAY - Jaco
"Big Rug" Raceway of Indiana - Marion County Fairgrounds
Team BlackOps
I stumbled through it, the you-tube link was what did it for me though.
If you are just bashing I would not reccomend lundsford turn buckles. For that much money you could do a lot more. Even if you were racing, one set would be sufficient, but still a bit spendy. Just my 2 cents!
