Originally Posted by vic0280
hey guys gonna pick up a used 18t to beat on in the yard with my son.
question.
will the hitec 5245 mini servo fit. i have one laying around from old something or the other.
Vic - I used the servo in this link. It fit but I had to trim the screw mount holes just a hair over in the chassis. So if your servo is within the dimensions of this one it should work. The only dimension that would potentially be a problem really is the width side to side. You might need to buy the hitec mounts or make your own out os some plastic also. The ae one probably won't work for ya. Or if it's even a little bigger ya might just be able to shoe goo it down. I love the shit out of this 18T man. Can't believe how fast it is with a stock motor!
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLGJ5
I just put a lrp quantum 2 in the truck. The stock speedo really has identical performance plus reverse. The qc2 seems to have a bit better brakes though.
Finally got things mounted how I like too. I put the speedo on the top plate, direct wired to the motor and a mini deans on the batt wires. The rx I mounted right on top of the servo. Seems to be a better configuration this way and more user friendly. If I get some time this summer I may make my own chassis out of some CF sheet. Should be pretty neat, and not to difficult. We'll see.
My dx3r and older spek rx (3000 I think it is) works great on the truck. I have no problems with it starting right up and binding together. This was with the stock speedo, so no problems with my spek stuff working in the truck.
Does anybody have any problems with the hitech hs 65 mg, kind of wigging out now and then? Like the motor is just spinning around really fast and the wheels are locked? It just does it now and then, and all it takes is wiggling the steering wheel to get it to unlock and work properly. Works excellent besides that.
