Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-15-2008, 01:23 AM   #721
Thomas P's Avatar
Questions?? SETUP TIP
Hello...is there anyone that may give me some helt for my setup?
Im running my TEK18X with a micro BJ4WE lid. me and my clubm8 are changeing tip and tricks betwen us...up to this day we, or i am running
front
Gold front 70w oil
2nd hole on tower from outside
Inner hole on arms
Pro C casterblock
Pro steeringblock, lower hole
Longest upper link
1.5deg camber
bones level
Rear.
Gold rear 35w oil
Inner hole on tower,
Outer on arms
1.5deg camber
bones level
1.5mm limiters
AE RC18 Foams trued to 49mm tracktion 100% rear and 1/4 on front (inner side)
Ok, here is the deal...the car is performing REAL good, our track have real big jumps, but a GOOD flow. but my car if i do a little longer jump, so i miss the landing, or even a smaller jump, after landing, the car can suddenly change direction i mean it bumps up...are,or my car to hard,soft,less pack,more pack? any tip here?
sometimes, or i think it IS, twitchy, little nervous on stering, not sure, i think it is after it is offpower or it is after landing, and it change direction...
what i WANT is, to have my car to soak up the landing better..but this track have some HUGE jumps and the car is little...
a pic..
ANy tip would be G
Skyrocketbatteries | TpParts - hand made CF parts, straps,Xray chassis etc
Xray M18T Pro - eZrun25A - 7800 - Spectrum - Ko - Gecko
Thomas P is offline   Reply With Quote
Old 11-24-2008, 04:47 AM   #722
hey there i really want to get a truggy for some bashing and i live in malaysia and over here ive seen this around http://www.eworldtoy.com/new4wd1elesc.html
it is meant to be a direct copy of the rc18 but at about 75 $!! which is like 4 times cheaper then the rc18 over here in malaysia
has any 1 tried 1 of these out before?
scottwhat12 is offline   Reply With Quote
Old 11-24-2008, 07:35 AM   #723
Suspended
Originally Posted by Thomas P View Post
Hello...is there anyone that may give me some helt for my setup?......
what i WANT is, to have my car to soak up the landing better..but this track have some HUGE jumps and the car is little... ANy tip would be G
By the looks of your track it appears you're going for bigger air than these cars were ever intended for, which could be a major part of the problem. Oftentimes our expectations for these little cars are more than they can handle.
Your basic set-up looks OK, but as far as it being "twitchy" you might want to check the toe adjustment. IMO a miniscule bit of toe-out could help with that, along with changing over to Blue Rear springs. Matching f/r springs will make it twitchy.
theDr is offline   Reply With Quote
Old 11-24-2008, 11:40 AM   #724
A.Galenski's Avatar
you said you're running pro c castor blocks, if you're talking about the exotek ones try going back to stock castors blocks. my opinion is the exotek ones give you more on power steering, or try running the short front camberlink. i would also suggest a softer spring in the rear.
have you tried rubber tires yet? on my buggy i use losi street meets and i use crc 1/12th magenta foam donut as an insert.
Team Associated / LRP / Reedy / Team Scream /Exotek / Team BSR / RC Madness
A.Galenski is offline   Reply With Quote
Old 11-26-2008, 10:12 AM   #725
jman37's Avatar
Just installed a HS-65mg servo in my rc18. I am having problems with it glitching. It turns to the left fine but sometimes it only turn 1/2 way to right. also when I turn the car on, the servo starts glitching back and forth a very small amount just like its spazzing out or w/e. It also get hot after only a few minutes of bashing around.
I use a spectrum dx3r with 3000 receiver. I dont know if I just have a bad servo or what.
Thanks for any advice!
J
On the mountain of the lord it will be provided.
jman37 is offline   Reply With Quote
Old 11-28-2008, 07:03 PM   #726
sim600's Avatar
Trader Rating: 14 (100%+)
Send a message via ICQ to sim600
I should have asked on this thread instead of starting a new one on the main forum. I did a search but couldn't find an answer.
I'm planning to run a mamba 6800 in my RC18B on a carpet track. Should I upgrade the diffs to the MIP super diffs, or will the plastic ones with the reinforcing sleeves last a long time?
Thanks in advance.
sim600 is offline   Reply With Quote
Old 11-28-2008, 08:18 PM   #727
geeunit1014's Avatar
Thanks in advance.
as long as they are are built/shimmed properly you will be fine
Mike Gee
Team Driver For: Exotek/Castle/Psycho Cells/GQ Tires/Darkside Designz/Rad Racing
Proud Supporter of: MRL (Micro Racing League) / Final Thoughts RC Club
geeunit1014 is offline   Reply With Quote
Old 11-28-2008, 11:49 PM   #728
sim600's Avatar
Thanks for the info. Now I can trim my shopping list.
Old 11-29-2008, 06:33 AM   #729
Suspended
As geeunit said, as long as you build them correctly, and maintain them, the stock diffs should be fine.
But unless you're running a pretty large carpet track you might want to think about a 5400kv motor instead of a 6800 as it will be a lot more usable and controllable.
Old 11-29-2008, 12:09 PM   #730
jman37's Avatar
Lookin to upgrade my shocks as the ones I have on my used RC-18 leak oil out badly. I used some teflon tape to keep it from leaking but they are worn and I just wanna replace them.
Was wondering if anyone had any suggestions as to what you use or what you have had bad experience with.
thanks,
J
Old 11-29-2008, 04:24 PM   #731
Suspended
Everything leaks badly if you don't rebuild them, replacing the o-rings and stuff, from time to time.
Old 11-29-2008, 04:40 PM   #732
jman37's Avatar
Are there any "upgrade" shocks out there that would produce a noticeable improvement in handling or should I just rebuild mine?
J
Old 11-29-2008, 07:12 PM   #733
Suspended
IMHO, no!
We're talking very small shocks and though others do exist, the basic design and performance varies little. The great thing about the AE shocks is that they're fairly easy and quick to rebuild and rebuild kits are cheap and easy to come by, something that can't be said by most of the others.
Old 11-29-2008, 08:27 PM   #734
jman37's Avatar
SOLD thnks doc
j
Old 11-30-2008, 11:50 AM   #735
jman37's Avatar
Lookin at a tek18x conversion and I must say it looks pretty shweeet..
It says its the off-road version. will this conversion be viable for a carpet track with a few jumps + mostly on road/ bumpy on road bashing?
Anyone who has gotten this conversion kit that could add there opinion of it and what types of surfaces you run it on would be great!
J
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
heli8ight
Forum Jump
** The Official HOT or NOT Thread *** JVT MTX3 Chat Lounge 2431 12-30-2007 04:19 PM
Official MT2 RTR Thread PowayLAX1 Electric Off-Road 18 03-20-2007 01:03 PM
LST Official Thread Whipple81 Monster Trucks 0 10-06-2004 10:30 AM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 03:09 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
