Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-29-2006, 06:48 PM   #46
crabboy's Avatar
Trader Rating: 31 (97%+)
Send a message via MSN to crabboy
Default PROJECT 'RC18R' COMPLETE!
Hi guys,
Well it took 2 months 1 digggity chassis kit 1 full set of monotuning wide track arms plenty of alloy 1 mamba 8000 6 nosram v-tec cells 1 KO servo and 1 factory team kit and now project rc18road is complete The car is set up for road only this car is never seeing the dirt first run will be today will get back to you on how it goes. Please leave your comments
official-ae-rc18-thread-124_2446.jpg   official-ae-rc18-thread-124_2447.jpg   official-ae-rc18-thread-124_2451.jpg
Rhys Marshall.
Team Losi Australia - 8ight 2.0
Factory McNugget Team Driver with BBQ sauce.
crabboy is offline   Reply With Quote
Old 07-30-2006, 12:21 AM   #47
muvro's Avatar
Hey guys,
I finally finished my FT 18T.
I turned everything to aluminium and carbon.
GPM carbon chassis
GPM front and rear diff housings
Integy arms uprights, shock towers, servo holder, bumper, rear toe mount.
MIP CVDs
AE MT wheels and tyres
Novak Micro GT
Orion Baja motor
Futaba 3103 servo
It looks awesome and is a lot stiffer than the standard gear.
My dilema is I put the first pack through it just an hour ago. Free revved it for a couple of mins with com drops to run the motor in. It got REAL hot...
Anyway, I took it for a run on a fresh battery after the motor had cooled... When I pulled the trigger, it took off fairly slowly and wound up to top speed, which was quite slow and disappointing. Rather than sprouting into life and taking off... After about 2mins of running the motor was bloody hot and the pack was warm too. So I let it cool. Whilst letting it cool I changed the gear ratio from the small spur and big pinion to the big spur. Keeping the big pinion. I double checked the mesh on the pinion to spur making sure to keep a tiny gap so there isn't too much friction from too tight a mesh. I also pulled the diff covers off to make sure the mesh of the diff gears were free. They had just the right amount of back lash. I checked all wheels and shafts. Making sure all were free. There is no tightness or friction.
It doesn't roll as good as my HPI Pro 2 (with no motor in it) But I just put this down to being shaft driven...
Anyone got any ideas?
I'm worried if I run it any more I'll burn the motor or speedy out...
PLEASE HELP???
I should add everything is brand new... If that makes a difference....
Are these Baja motors any good? I figured being an Orion motor it's be half decent.
muvro is offline   Reply With Quote
Old 07-30-2006, 04:55 AM   #48
HotrodHopkins's Avatar
Trader Rating: 30 (100%+)
Send a message via AIM to HotrodHopkins
Originally Posted by crabboy
Hi guys,
wow. that's awsome man. now, are you still gonna run it contantly? lol.
SHAUN HOPKINS a.k.a NoRod Hopkins
-1997 Dodge Ram 2500 Cummins 12v ECLB 4x4 5spd; 1990 Chevrolet K1500 Silverado TBI350.
-My lug nuts require more Torque than your Honda makes.
HotrodHopkins is offline   Reply With Quote
Old 07-30-2006, 03:39 PM   #49
Michael P's Avatar
here is mine rong wing mount on this pic i got a new one tho.
mike
Michael P is offline   Reply With Quote
Old 07-31-2006, 10:20 AM   #50
BadSign's Avatar
Default Driven Productions
I ran the DP steering link yesterday for the first time and it works very well. Between this and CompetitionX's servo saver mod, I have no slop or weak steering now.
Nice work, DP!
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 188:24
Jimmy!
BadSign is online now   Reply With Quote
Old 07-31-2006, 09:09 PM   #51
Rocket42's Avatar
ok i wanted to give a updateas to how cool my rc18b is now, i ordered the hex connectors that crabboy recommended, but after looking how far the axle sticks out i was worried the car would get too narrow so i ordered 2 sets. well when i put the one set on the car it was just slightly narrower than the stock wheels. well i wanted to make it wider and i ordered 2 sets. so i drilled them and epoxied them together and bam mini wheel extenders. the wheels still have the axles sticking out past the hub about 2-2.5mm so overall the width of the crimefighters tire is about in between the stock tires. this would be an awsome oppertunity to manufacter some mini wheel extenders cause after driving my mini with the crimefighter tires all i can say is wow.
the tires have raised the ride ht. which will make it handle rough tracks better as well as providing a killer tread pattern. with proper wheel extenders to remove any axle sticking out it would raise the ride ht. even further and the width would help with stability. with the larger tires when the car goes up on its nose the tires are tall enough to keep pulling instead of the nose sticking in. i can't wait to try it on a real track.
Rocket42 is offline   Reply With Quote
Old 08-01-2006, 05:58 AM   #52
thachowman's Avatar
Hi guys,
That is hot Rhys, well done, looks like a tiny FT TC4, what body you running, and is the 18th Truggy still going ? or has it been sacrificed for this monster ?? well done again.
Cheers
Chow......
_____________________________________________
Action R/C Team Schumacher Driver
Schumacher Mi4 -Mi3 - LRP - Spektrum - Ko - Action R/C
thachowman is offline   Reply With Quote
Old 08-01-2006, 06:07 AM   #53
crabboy's Avatar
Thanks Drew,
Can always count on you for some nice feed back The truggy is still going strong As for the body I am looking into a custom body by franksbodies When are you coming down to SA to see Hobby Habits indoor venue?
Rhys Marshall.
Old 08-01-2006, 06:31 AM   #54
thachowman's Avatar
I would love to come back down south oneday to visit some family there but it won't be in the near future, too many commitments here,besides I need some more practice before I come and race with you guys
Cheers
Chow......
Old 08-01-2006, 06:04 PM   #55
rm25x's Avatar
Send a message via Yahoo to rm25x
PLEASE HELP???
I ran that motor for 1 qualifier and threw it in the trash. It was slower then the stock motor that came with it. Went in and bought a Trinity Cobalt 16t. Ran 1 race, it sucked and gave it away. Went brushless and will never go back.
You never said what gear you were running for the pinion, but I wouldn't use anything bigger then 13t with that motor.
www.RadioControlDecals.com
rm25x is online now   Reply With Quote
Old 08-02-2006, 02:03 AM   #56
muvro's Avatar
Great!
Thanks for that... I think.. hahaha
Nah thanks!
The car seems to roll fairly freely. So there is something wrong... Looks like I might have to go the Mamba route...
With the normal battery packs what sort of run time am I looking at. I don't want something PSYCO!!! But something really QUICK. If I have interpreted the information correctly i think I want the 6.x k setup... Not sure exactly which one.
Which one did you choose?
I won't be racing it, mainly running around the street and general bashing. It's a bugger coz I just bought the micro GT for it.... Might be able to palm it off...
Many thanks for your help!
Cheers
Takis
Old 08-02-2006, 02:21 AM   #57
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
Great!
Nah thanks!
Cheers
Takis
dam dude....i just bought a brushless esc for my mini t...if i didnt i woulda got that micro gt off ya...
and by any chance r u greek?...im guessing u are...
ProudSavageOwnr is offline   Reply With Quote
Old 08-02-2006, 03:47 AM   #58
muvro's Avatar
Yeah, I'm Cypriot. LOL
Which Brushless did you get?
I'm thinking that this is the only way to go... The Baja is freakin crap!!!!! I mean I just can't get over how hot it gets... Damn rip off crap!!!!!
The car looks so good but it just goes like crap!!!! It has really turned me off the car... If I didn't buy the bling for it I'd have sold it already.... Too much coin spent on it but... Mind you if I got offered the right money I'd probably take it...
Is there any good brushed motors out there that are decent?
Old 08-02-2006, 03:55 AM   #59
rm25x's Avatar
I am running the Mamba 6800 setup. Run time is awesome, and it runs cool sticking with stock gearing. Its quick too. I would say with a 1100 pack run times are 20-25 minutes.
Never ran a brushed motor that ran half as good, and I have tried them all. The stock motor was pretty much the best, so you can get an idea there. This is my second 18T I went brushless with.
Old 08-02-2006, 03:57 AM   #60
muvro's Avatar
Here's a pic of the car.
Haven't painted the body yet... Too busy...
Forum Jump
** The Official HOT or NOT Thread *** JVT MTX3 Chat Lounge 2431 12-30-2007 04:19 PM
Official MT2 RTR Thread PowayLAX1 Electric Off-Road 18 03-20-2007 01:03 PM
LST Official Thread Whipple81 Monster Trucks 0 10-06-2004 10:30 AM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 03:09 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
