Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-22-2007, 08:03 AM   #556
MikeXray's Avatar
Trader Rating: 24 (100%+)
Originally Posted by mugendude View Post
thier prices arent that bad but shipping could kill somebody but i had never had a problem with these guys i would rather spend the extra money and know i will be recieving my stuff
If I order the spur cover, drag link, spring cups and wheel adapters its $20 for parts that easily fit in a $4 priority box, if it was like $8 I say ok, but come on.
Mike L.
www.MikeLdesigns.com
Schumacher Mi3.5, Losi TypeR
Losi XXX-CR, Kyosho ZX5 SP - http://www.raceway.com
Kyosho MR02 Mini-z - Http://Majshobbyshop.com, http://www.nyrcsuperraceway.com/
MikeXray is offline   Reply With Quote
Old 06-22-2007, 09:23 AM   #557
DFroyd's Avatar
Originally Posted by MikeXray View Post
Does anyone besides thetoyz sell the driven products? I don't feel like getting bent over by their shipping prices.
We have a LHS that handles the link but for what they mark it up plus tax, it's cheaper to order it with shipping I've seen it available on ebay too but the cost is similar.
DFroyd is offline   Reply With Quote
Old 06-22-2007, 10:26 PM   #558
utahrcracer's Avatar
so I got my mamba 6800 today and my RPM blue bumper shock towers and A arms!!! SWEET I should get my drag link tomorrow, good thing the freakin truck can't go in a straight line to save its life hahaha. So question my car sounds like crap I have a 13 pinion and whatever the stock one is in the FT kit? any help here what should I be running pinion/spur with the 6800? Also metal spur gear? I have heard they are noisy but I can't imagine this stock one will last long. Anything else i should get come on guys help me build the dream truck
brushless MLST
utahrcracer is offline   Reply With Quote
Old 06-22-2007, 10:31 PM   #559
I got mine from toyz on ebay it was 12.99 I think with shipping for the drag link...... if it works as well as I have heard here it will be WELL worth it
brushless MLST
Old 06-23-2007, 12:36 AM   #560
JeromeB's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to JeromeB
Check your gear mesh for noise, its not meant to be completely silent though.
If its too loud = mesh is too tight
wheels dont sping = mesh is too loose
you should be able to rock the spur gear in between the teeth of the pinion without it moving
JeromeB is offline   Reply With Quote
Old 06-23-2007, 05:11 AM   #561
you should be able to rock the spur gear in between the teeth of the pinion without it moving[/quote]
see I can do that, the wheels don't spin, it is really loud though. I have the motor as far as it will go over and then some I had to dremel out a little plastic just to get it where it is now!!! I really like this truck but AE really screwed up a couple things on it, like steering!!! hahaha
brushless MLST
Old 06-23-2007, 05:26 AM   #562
JeromeB's Avatar
I disagree, I think that the steering system is very effective and simple, but yes it is sloppy but people have covered up for this and it is very easy to fix.
I didnt like the motor mounting system either, I can run a spur higher than 55 (not that I want to) because I cant get the mesh right.
Overall best 1/18 there is!!!!!!!!!!!!!!! Its Associated
Old 06-23-2007, 06:53 AM   #563
No I agree I just think the steering is really week, oh well keeps aftermarket companies busy! I am very happy with the truck I can't wait to get it all the way I want, I am so picky though. I am not even racing it just playin at the park and backyard but I still want it smokin! Thanks for the help Jerome!!
P.S. my avatar rocks harder than yours!!! HAHAHA
brushless MLST
Old 06-23-2007, 04:18 PM   #564
losi guy's Avatar
Trader Rating: 23 (100%+)
Can anyone tell me if i can use my spectrum radio with the stock speedcontrol on the 18t?
Fantom Racing | Spektrum
losi guy is offline   Reply With Quote
Old 06-23-2007, 05:24 PM   #565
JeromeB's Avatar
My RC18T has not 1 single hop-up/aftermarket peice besides the drag link and gear cover.
Ive done the o-ring mod and it helps too.
My electronics go as follows:
LRP A.I runner reverse
Super 370 ($12 stock motor and Im running 15/55 and Im faster than my friends mamba 5400)
Hitec HS-56hb
Spektrum micro rx
If you want my setup I can pm you, its for a 60% clay track with a fine layer of sand ontop with very little grip.
PS!!!!!! IF ANYONE HAS VENDETTA WING MOUNTS I WANNA BUY THEM OFF YOU!!!
Old 06-23-2007, 05:25 PM   #566
JeromeB's Avatar
Some people have had problems before, but read my above post ^, I use different electronics
Old 06-23-2007, 06:43 PM   #567
losi guy's Avatar
Thanks, i'll give it a try if doesn't work i have other electronics that i can use.
Old 06-23-2007, 07:47 PM   #568
chris_mtb's Avatar
Send a message via MSN to chris_mtb
im getting replacement diff gears will up grade later
is it worth gettin the FT
next time i might go for the FT truck or a vendetta i heard they have alot of room and the gears are all covered so no rocks get in
i got a dremel branded dremel today so im happy
also im thinking of getting the rpm blue front bumper
does it make a difference with jumper like extra weight in the front
my rides
rc10b4
13.5 novak brushless
lipo
rc10b44
novak 10.5 brushless
tt01 drifter
with led and silvia body =]
chris_mtb is offline   Reply With Quote
Old 06-23-2007, 10:45 PM   #569
JeromeB's Avatar
Wooo dremels are cool, which one did you get? I got the 400xpr
ALSO! Anyone know if the vendetta wing mounts are a direct fit onto the
RC18T?
BTW chris Ive had no problems with stones in the diff housings, only minor dirt but it doesnt affect anything. I used to have problems with tiny stones in the spur getting lodged, but I ran my car with the dp gear cover and St.Ives the other day (the track has like 2cm thick layer of sand ontop) and I didnt have a single problem.
Old 06-23-2007, 11:25 PM   #570
Today I installed an RPM bumper, arms, shock towers. Also installed my mamba 6800! I have the drag link coming anytime now in the mail. My only problem is I can t seem to get my pinion close enough to my spur gear!!! Has anyone else had this problem? I have the FT motor mount, it is is close as it can get without having to dremel some plastic.
So after all this work and I can't drive it because I don't want to burn up the spur.
brushless MLST
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
allcleanedup , KROGOTH
Forum Jump
** The Official HOT or NOT Thread *** JVT MTX3 Chat Lounge 2431 12-30-2007 04:19 PM
Official MT2 RTR Thread PowayLAX1 Electric Off-Road 18 03-20-2007 01:03 PM
LST Official Thread Whipple81 Monster Trucks 0 10-06-2004 10:30 AM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 03:09 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
