Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-10-2007, 10:54 AM   #331
ae4ever's Avatar
What servo are you using? I had the same problem and when i changed servo the drifting went away. also make sure the bottom of the servo saver is not rubbing the chassis.
ae4ever is offline   Reply With Quote
Old 02-10-2007, 12:37 PM   #332
Send a message via AIM to T1bobo
Ok guys the problem is clear i dont know why but it just started to work but now i have a new problem in order for me to run the drag link i had to shave some off the inside off the hole where the balls go but i took to much off and now has slop again is there no hope for this anymore?
T1bobo is offline   Reply With Quote
Old 02-12-2007, 03:04 PM   #333
slowpokeRRR's Avatar
can any one help me with my gearing issues i am running a quark 33 with 17/51 gearing and i cant get it to not cog is there anything i can do to make it work. there are claims that 19/51 gearing can be used with a mamba 25 i thought that the quark was suppose to be a better speed control...........is there anyone who can help should i put bigger gauge wires on it or what
slowpokeRRR is offline   Reply With Quote
Old 02-16-2007, 01:06 AM   #334
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
if your using deans connectors....throw em away....use corally or 3.5mm bullet venom plugs....thats wat i got on my mamba with 19/51 gearing and 3 cell lipo and it aint cogging at all.....
ProudSavageOwnr is offline   Reply With Quote
Old 02-18-2007, 07:12 AM   #335
MADMAN23's Avatar
Trader Rating: 6 (88%+)
Send a message via AIM to MADMAN23
Cool
ok i have a little problems... when i turn on the radio and plug in the battery pack., then turn on the switch.. the light on the esc go's red... and i can not move the steering .. or give it any throotle... but when i move the wire where they plug together it works... i was wondering if it the plugs ... and i have 1 more problem .. when i charge the stock pack it dont charge to 1100 mah...and i charg it at 1.4 amp this pack has only been charge maybe 11-15 times ... PLEASE HELP MY RC LOL
MADMAN23 is offline   Reply With Quote
Old 02-19-2007, 01:05 AM   #336
what kinda esc isi t?
run down the pack and charge at somethinglike 500mah or so for a few cycles....itll get it back up
Old 02-19-2007, 06:49 AM   #337
MADMAN23's Avatar
its the stock esc... ok i will cycle it ....
Old 02-19-2007, 08:17 AM   #338
chadlow21's Avatar
oval chassis
Hello everyone, I recently started racing carpet oval with my 18T and I was wondering if anyone knew of any other place to get a Diggity chassis, or if there are any other companies that make a CF oval chassis for the 18T.
chadlow21 is offline   Reply With Quote
Old 02-19-2007, 08:36 AM   #339
Hey T1bobo,
I shaved a hair off the inside holes on my draglink as well - but just a hair!
Mine is working fine. You can get another one from BMI Hobiies - Jessie has them in stock. But he is closed Mon and Tues.
With the servo saver and the steering setup - I personally do not beileive you will ever get it perfect - like a 1/10th touring car.
But sometimes "close enough" is close enough.
bbking9 is offline   Reply With Quote
Old 02-19-2007, 04:36 PM   #340
MADMAN23's Avatar
Thumbs up
oh yea dose a stock rc18t when the battery pack get low dose your steer to one side? and also sometime take"s off ?lmk
Old 02-19-2007, 07:36 PM   #341
Yeah mine does this to its just letting you know that its out of juice and to stop running it
Old 02-19-2007, 07:39 PM   #342
Originally Posted by bbking9
Hey T1bobo,
Dude i had so much fun running them on sunday it was te first time it had seen the track and it showed but i will be at BMI on sunday to race maybe in the open class and you better be there....or else
Old 02-20-2007, 06:53 AM   #343
MADMAN23's Avatar
Thumbs up
ok dose your 's when you first plug it in.. take a little bit.. then you have control of the rc.. because mine dose.. and are you useing the stock plugs? if no what are you useing?
Old 02-20-2007, 03:23 PM   #344
chadlow21's Avatar
I was hoping I could get some help, but no responses? I want to know if there are any other places that sell diggity chassis, or if there are any other companies that make a carbon fiber oval chassis. Thanks
Old 02-20-2007, 05:35 PM   #345
MikeR's Avatar
I think Diggity sells direct and are the only ones for oval that I know of.
www.exotekracing.com R18☆TEK18X☆TRF TA05R☆HB CYCLONE☆AE TC5☆HPI PRO4☆LOSI LXT☆M18 R3☆AE B44☆HPI CUP RACER
EXOTEK WILL BE CLOSED FOR VACATION 11/24 - 12/11
MikeR is offline   Reply With Quote
Forum Jump
** The Official HOT or NOT Thread *** JVT MTX3 Chat Lounge 2431 12-30-2007 04:19 PM
Official MT2 RTR Thread PowayLAX1 Electric Off-Road 18 03-20-2007 01:03 PM
LST Official Thread Whipple81 Monster Trucks 0 10-06-2004 10:30 AM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 03:09 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
