Originally Posted by jeff jenkins
quick question... if you run a lipo thats a 3-cell 11.1 volts is it safe to use with the stock set-up electronics with out damaging them?
According to the Tower Hobbies the answer is no, it is not safe.
NOTES FROM OUR TECH DEPARTMENT
This is the stock replacement XPS 8023AE Micro Electronic Speed Control
for the Team Associated RC18T truck - ASCC2010.
FEATURES: Direct replacement ESC for the RC18T
Forward and reverse with switchable forward-only racing mode
Uses the latest SMD-MOS FETs
Plug-and-play setup
Pre-installed motor leads with connectors
Pre-installed battery leads with micro connector
Pre-installed radio lead with Futaba J style connector
Pre-installed ON/OFF switch
INCLUDES: One micro size speed control
One blue anodized aluminum heatsink
Two pieces of heatsink mounting tape
REQUIRES: Mounting to the model with servo tape - ASCC2785
SPECS: Length: 1.02" (26mm)
Width: 1.02" (26mm)
Height: .61" (15.6mm)
Weight: 1.09oz (31 grams)
Voltage input: 4.8-8.5V
Internal resistance: 0.0045Ohm
Momentary load (1 second): 50A
Brief load (30 seconds): 30A
Continuous load (5 minutes): 20A
BEC voltage: 5V
BEC current: 1A
Frequency: 2.8KHz
