Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 12-28-2006, 05:10 PM   #211
Quinton's Avatar
Use TC3 body posts. They fit right in perfectly
PowerHouseRC@hotmail.com
LCG EXT 3 spd Savage - Yokomo GT-4
XL-5 Stampede - Evader
R/C Suzuki Motorcycles
Quinton is offline   Reply With Quote
Old 12-28-2006, 08:14 PM   #212
BimmerDriver's Avatar
I've read nearly every page here and nobody has mentioned the differene between the 280 motor in the RC18T and the "super" 370 motor in the RC18B. Anyone have experience with these? What is the deal?
BimmerDriver is offline   Reply With Quote
Old 12-28-2006, 08:42 PM   #213
Bermbuster's Avatar
they both are closed end bell stock motors. They gave decent speed but once they wear they lose speed.... Most people run them for a short amount of time then hop up.....
I remember the 280s didnt last long. I know mine was replaced by a mini max....
Bermbuster is offline   Reply With Quote
Old 12-28-2006, 09:57 PM   #214
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
Originally Posted by wireman
Has anybody mounted a late model body to an rc18t?? I bought one and was ready to start mounting it and suddenly realized that the tiny mounting posts on the stock shock towers were way too short, and I can't find an aftermarket mounting kit. I really hate to break out a Dremel and start jury rigging something up, but I may have to. Any help appreciated!
u may have to unless u get like integy or sumthing shock towers which have longer posts......i know i had to for my hummer....
ProudSavageOwnr is offline   Reply With Quote
Old 12-29-2006, 05:19 AM   #215
HotrodHopkins's Avatar
Trader Rating: 30 (100%+)
Send a message via AIM to HotrodHopkins
can't stand the 280, too slow, i get can good speed out of the 370 with the right gearing.
SHAUN HOPKINS a.k.a NoRod Hopkins
-1997 Dodge Ram 2500 Cummins 12v ECLB 4x4 5spd; 1990 Chevrolet K1500 Silverado TBI350.
-My lug nuts require more Torque than your Honda makes.
HotrodHopkins is offline   Reply With Quote
Old 12-29-2006, 09:25 AM   #216
t9dragon's Avatar
Send a message via ICQ to t9dragon Send a message via AIM to t9dragon Send a message via MSN to t9dragon Send a message via Yahoo to t9dragon
Try www.thetoyz.com he has some aftermarket shock towers for the 18t.
t9dragon is offline   Reply With Quote
Old 12-29-2006, 09:47 AM   #217
Centerline Racing's Avatar
Trader Rating: 28 (100%+)
Default AE18T Body Options
Nitro TC3 Rear body mounts AE #2230 are an exact fit.
As for the front, stock works for the PTI R-390 (#915003) body I put on mine. I had to sand off the 'washer' parts so the posts stuck up more thru the body
Allan
Centerline Racing is offline   Reply With Quote
Old 12-30-2006, 07:30 PM   #218
Send a message via AIM to wireman
Thanx for the help guys, think I am gonna try those NTC3 body post.
wireman is offline   Reply With Quote
Old 12-31-2006, 09:32 AM   #219
Just a quick noob question....but why is everyone mounting there rear shocks on the inside rather than the outside???.....it looks like the only affect is that it gives the car a tiny bit more wheelbase being the way the lower arms are made.....????
slicvicpr87 is offline   Reply With Quote
Old 12-31-2006, 08:05 PM   #220
your completely right......and this does help with stability....ive done the front and back and its great for high speed...very stable
Old 12-31-2006, 09:16 PM   #221
Doing my due diligence here before purchasing an RC18. I like the looks of the RC18B more than the RC18T, the MT is not in consideration. Where I plan to race is a carpet track, they run foams. The RC18B has narrow front wheels and wide rears, where the 18T has wide wheels all around. I've only seen 1 size foam tires, how do they fit on the 18B?
Old 12-31-2006, 09:39 PM   #222
Quinton's Avatar
The B, T, and MT are all basicly the same truck. Doesn't matter which one you get - the foams will work. I started off with the Factory Team version, my friend started with the MT; they can be made identical within 15 minutes.
Old 12-31-2006, 10:05 PM   #223
Thanks Quinton. I'm on a really tight budget, thinking of going with the RTR to get the electronics, motor and battery. Is there much of an advantage to getting the FT over the RTR?
Old 12-31-2006, 10:18 PM   #224
Bermbuster's Avatar
The FT comes with some really good hop ups......
threaded aluminum shocks, hs motormount, ti adj tierods, carbide diff balls,aluminum dog bones (good but MIP cvds are the best) cf battery strap, servo saver and pinion assortment. (hop ups are almost the cost of the kit)
Since you are on a budget the rtr will be a good way to start out. The stock radio is pretty good for an AM radio. Then down the road as you get some cash you can upgrade. First off invest in a good peak detection charger
about $50.
Old 12-31-2006, 10:54 PM   #225
about $50.
Thanks Bermbuster. I know about the radio, got one with my RC10GT+ RTR. It's not a bad radio, I might stick with it to see how precise I need to be with a little truck/buggy. Later on get a SR3500 receiver and use my Spektrum transmitter if I need better DR adjustments. And I already race electrics; I have an ICE charger.
I believe sometimes it's hard to justify the cost of a kit, when an RTR can get you racing so much quicker. Even if I use my Spektrum or XS3 radio I'd still need a battery, ESC and a motor. That's another $50+ over the cost of the RTR and I don't have to take one of my cars apart.
Forum Jump
** The Official HOT or NOT Thread *** JVT MTX3 Chat Lounge 2431 12-30-2007 04:19 PM
Official MT2 RTR Thread PowayLAX1 Electric Off-Road 18 03-20-2007 01:03 PM
LST Official Thread Whipple81 Monster Trucks 0 10-06-2004 10:30 AM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 03:09 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
