Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-23-2006, 12:09 AM   #181
mi wheels- mini inferno or half 8 wheels. i whant to put a set of proline crime fighters on my 18b.
rc_advil is offline   Reply With Quote
Old 11-23-2006, 04:47 AM   #182
Bermbuster's Avatar
mi wheels fit on the rc18b no problem. You need to use mi hexes though. You can use plastic or aluminum hexes. You may also want to use a spacer on the axle shaft (outside of the wheel) when you tighten down the axle nut you will notice you have a lot of exposed thread (axle is long) if you leave the exposed thread and crash you may have trouble removing the elastic stop nut.....If you have old or extra nuts they work. I found nylon spacers at Sears Hardware.
Bermbuster is offline   Reply With Quote
Old 11-23-2006, 01:18 PM   #183
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
ohh soz my bad..i usually refer to em as H8
ProudSavageOwnr is offline   Reply With Quote
Old 11-23-2006, 06:47 PM   #184
does any one other than kyosho make the hex adapters?
Old 11-23-2006, 08:18 PM   #185
Bermbuster's Avatar
yep....3r atomic and integy.....they arent expensive either....if you buy the 3r wheel/tire combos they come w a plastic hex.....
Old 12-05-2006, 09:15 AM   #186
Yo Berm, You shouldve came out to race this sunday it was fun....i finally tested out my RC18t with my touring car shocks/springs on em.....it handled sooo nice.....I got this thing dialed for carpet....all i need is to take out the slop with a drag link
slicvicpr87 is offline   Reply With Quote
Old 12-05-2006, 05:35 PM   #187
mentallylost's Avatar
slicvicpr87,
Any pics of that TC shock/spring setup?
Which ones did you use?
mentallylost is offline   Reply With Quote
Old 12-05-2006, 06:41 PM   #188
Ok, my 18t has developed this clicking noise in the rear diff everyone talks about. Does the MIP diff take care of this along with cvd's? Its going to be used for carpet racing so would it be a good idea to install one in the front also?
I'm new to electric and carpet racing (nitro junkie) Crooked J racing shows to use 80wt in the front and 40wt in the rear. Could you explain why? And how much should it be lowered?
MJ86GT is offline   Reply With Quote
Old 12-05-2006, 08:08 PM   #189
i figured out the hex hubs.
on a different note this thing is hooked up with the crime fighter tires on it, and it also looks totally bitchen. not only did i use half 8 tires and wheels but i also added a half 8 wing and a mini bj4 body. this thing handles and looks like an 1/8 scale.
Old 12-05-2006, 08:23 PM   #190
MentallyLost,
I used HPI shocks and springs all around.....the front are aluminum threaded and the rear are plastic threaded....the springs are HPI silver (# HPI6825)
lol modification to the rear shock tower was needed. Only drilling out the holes for the bigger ball studs. The front took alot more mods because of the smaller shock tower...had to cut the springs and also shave down the bottom ball cup to allow more suspension travel....I will try to post pics....
I couldnt deal with the light 2.5 lbs/in AE springs i needed stiffer to correct all the body roll so i threw these HPI ones ..(there only 7.5 lbs/in!!) and it handles NICE!
Old 12-05-2006, 11:36 PM   #191
heres my rc18t with 3 cell lipo,mamba and dynamiet 8000kv....14/60 gearing for now....had 55/15 but stripped the 55 spur.....anybody got any spare 55t spurs i can have/buy off them?
the wing is to keep it from swerving side to side at high speeds.....the rear springs are VERY hard to compress....about 1or 2mm of dampening occurs in the back....and the front goes down under the speed from the wing downforce.....
the clicking noise in ur diff means its slipping.....shim it up with a couple of shims and it should work for awhile
anybody wana input if i should buy a monotuning kit or new era alloy arms? i keep bending/brakin the bottom arms.....any if the monotuning ones are good can som1 gimme a link
ill have to upload the piks later on.....somthing wrong with the bluetooth on my computer
Old 12-06-2006, 12:45 AM   #192
warpig's Avatar
Instead of replacing the shocks with ones that have stiffer springs maybe put internal limiters in the shocks to reduce body roll and to give you a smoother transition from high speed to low speed cornering. It also gives more on power steering. I worked on different amounts of droop and came up with a great front/rear combo that makes my trucks corner speed out of this world. It has the corner speed a 1/12 onroad car. I run gold springs in front with associated 60wt with about 1.5 mm of droop in front. In the rear I have the blue springs with 40wt associated with 2mm of droop. There is a few other things I did to get the corner speed. But, I just think stiffer isn't the way to go. Adjusting droop is.. Just my opinion of course... just trying to help.
It's a new day! :)
PLUG IT IN, TURN IT ON, DRIVE!!! MAN, I LOVE ELECTRIC.
warpig is offline   Reply With Quote
Old 12-06-2006, 06:02 AM   #193
I just dont like the way to weight is thrown around so easily with the AE springs. For carpet i would guess you would want to run stiff springs and heavy shock oil. The AE springs are made for offroad so theres not much stiffness even with the stiffest springs they offer. I think its a bit much to put 70wt shcok oil in a small 18th scale car to stiffen up the suspension. Well i TRYED both ways and like the TC shocks/springs better.....if you guys dont think it will work but untill you actually try it you wont know for sure. Just my 2 cents
Old 12-06-2006, 10:18 PM   #194
have you got any piks of your setup? cause my shocks that im usin are from a kyosho fw05 and i had to put about 8mm of full tubing inside so that i could get it to a good height and not have like 4cm of ground clearance..
Old 12-07-2006, 08:12 AM   #195
nah no pics i will try to steal my girlfriends digicam to take some picks .....i also just noticed that AE VCS micro shock springs fit the original RC18T shock bodies...hmmmm
Forum Jump
** The Official HOT or NOT Thread *** JVT MTX3 Chat Lounge 2431 12-30-2007 04:19 PM
Official MT2 RTR Thread PowayLAX1 Electric Off-Road 18 03-20-2007 01:03 PM
LST Official Thread Whipple81 Monster Trucks 0 10-06-2004 10:30 AM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 03:09 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
