i dont agree with you on that one...
3. Use the DP draglink. No others work as well.
i made my own drag link out of 2 mini t oil shock rod ends and a turnbuckles n a couple of nuts n bolts and it works a million times better....and i doubt it can snap cause its high tensile steel and the ball cups will not come off
also the clicking sound starts to come from the diffs......the gears are wearing in and the bearings are getting worn out......try get some rubber sealedbearing for the diffs.....well pretty much all round....metal sheilded SUCKS and i needa replace bearings already
wen u start to hear clicking add in another shim to the diff ..... may feel tight at first but itll wear itself in..speaking of which i gotta do this to my rear diff now.....
and if your running on low traction surface and using stock electrics and like a 6 or 7 cell the diffs will probably last forever , this will happen if your running high power through it.....eg mamba with 3 cell lipo and 5400kv with low gearing and tall gearing.......and foam tyres
thats about it........
if ya interested in one of those draglinks i made pm me and we can sort somthing out
