So I recently purchased an FT RC18T and bought the Associated Factory Team MIP RC18T Swing Shaft CVDS axles for both the front and rear of the truggy.
I am using stock differentials, and on the outdrives for the diff's comes with anodized aluminum tubes that perfectly cover the outdrives to keep them from spreading under torque, when a dogbone/CVD is in place.
Has anyone had problems installing the aluminum outdrive re-enforcers over the nubs on the drive shaft? Am I going to have to grind a few millimetres off each nub on the end of the drive shaft so that the support will slip over the outdrive? Anyone have any ideas on this?
The CVD's I am using are these:
http://www.thetoyz.com/cart/thetoyz_...cat_name=RC18T
**IF you look at the picture in 3DE's post, you will see the re-enforcer I am talking about, its the blue part around the outdrive where the dogbone/cvd goes into the diff.
