Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-28-2009, 03:11 PM   #1531
hairymuffin's Avatar
guys im having major trouble with my steering....It keeps coming off centered.. I have a thick servo steering spring..I am running the Exotek chassis with hitec 65mg servo...I dont want to crank down on the servo nut too tight but it is snug....What causes the servo to keep off centering? It will either pull to the right very hard or to the left????
hairymuffin is offline   Reply With Quote
Old 07-28-2009, 04:09 PM   #1532
mlight13's Avatar
Are you running the stock motor or brushless? I have a 7800kv brushless on mine and it runs straight on full throttle, but once I let off the throttle, it veers hard to the left. My guess is that it is torque steer of some kind. With the stock motor, it did it a little bit, but not that bad.
Mark
RC18R - Stock
RC18T - Mod Brushless 7800kv
SLASH - Stock Spec
mlight13 is offline   Reply With Quote
Old 07-28-2009, 05:44 PM   #1533
I run brushless. It will run straight until I crash. And then my wheels will be turned to one direction....Maybe the servo nut is backing off and I may need to use locktight
Old 07-28-2009, 07:36 PM   #1534
myrxseven's Avatar
Maybe the crashing has something to do with it?
CRC Gen XL 17.5 1s Lipo
Spektrum l Novak l Tekin l SMC l Jaco
myrxseven is online now   Reply With Quote
Old 07-28-2009, 08:19 PM   #1535
its not an impact crash. just simple mishaps on the track. maybe I will search for old post incase anyine has had the same problem
Old 07-28-2009, 08:56 PM   #1536
should be getting my rc18t tomorrow
mcdragon2 is offline   Reply With Quote
Old 07-28-2009, 08:58 PM   #1537
9six7nine2bOI's Avatar
get the driven production's draglink.....
also cut a small groove around the servo saver n put a coil or 2 of mini springs in the small groove u cut into the servo saver....
9six7nine2bOI is offline   Reply With Quote
Old 07-29-2009, 03:02 AM   #1538
nvm i didnt read ur previous post.....
Old 07-29-2009, 08:00 AM   #1539
IIGQ4U's Avatar
Trader Rating: 23 (96%+)
Check the play in all of your links. Be sure to also check your servo itself and rotate the spline to see if there is play there as well.
IIGQ4U is offline   Reply With Quote
Old 07-29-2009, 09:06 AM   #1540
trdsupra88's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to trdsupra88
Sounds like the spline teeth on the servo horn could be slightly stripped. I had that problem to where if I hit something while steering it would jump a few teeth and just got worse and worse...take $10 and replace all the steering parts...
I cut my own hair
trdsupra88 is offline   Reply With Quote
Old 07-29-2009, 07:00 PM   #1541
BIG DADDY8's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to BIG DADDY8
Does anyone know what the degree is for the rear arm mount is?
BIG DADDY8 is offline   Reply With Quote
Old 07-29-2009, 07:19 PM   #1542
trdsupra88's Avatar
Im curious too...It looks like 2-3*,
I cut my own hair
Old 07-29-2009, 07:26 PM   #1543
BIG DADDY8's Avatar
hot-racing sells 1,2, & 3 degree. It's probably 3 degree.
Old 07-29-2009, 08:07 PM   #1544
anyone know about the sportwerks esc/receiver
I got my rc18t today and the esc/receiver seems off as the motor always runs ans the tx only changes the speed slightly not stopping it
Old 07-29-2009, 08:59 PM   #1545
Bingo! That is exactly whats happening. I will do that,thanks!
Forum Jump
** The Official HOT or NOT Thread *** JVT MTX3 Chat Lounge 2431 12-30-2007 04:19 PM
Official MT2 RTR Thread PowayLAX1 Electric Off-Road 18 03-20-2007 01:03 PM
LST Official Thread Whipple81 Monster Trucks 0 10-06-2004 10:30 AM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 03:09 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
