well guys i just got my rc18b and all i can say is wow.....every part packed in its bag....no parts trees ..... the only downsides are thescrews and ballstuds strip,the front shocks,no servo horn for a JR 375 so i drilled 1 out and stuck it over the huge spline,thediff screws and the instructions r sooooo confusing
a good thing tho is that i didnt have to grind my turnbuckles like some ppl had to and i love the blue anodized parts...totally wacky if u ask me lol
hey guys heres wat i came up with.......i snapped the shock tower so i thought ide make somthing different....i drilled the top shock mounting hole and put a long ball stud in there and had to shave away some of the diff case and the arms and i put the ballstud on the outter positions
IMO i think it works ALOT better than the stock suspension setup.....this lowers the CG abit and if ur running the buggy body u dont need the suspension tower....
i was running it today untill i went full speed into a lightpole and broke a steering knuckle...
handles alot better at higher and lower speeds and takes the bumps alot better
I put a rear tower and rear shocks on the front of mine for our large outdoor track. That helped tremendously as far as smoothing the truck out. Laying the shocks down like above should make it smoother in corners and not in bumps. It typically would give a little more roll and cause more bite in corners. But, of course with any tuning.. it's all just general probabilities. You could actually get the exact opposite effect. For examply.. in many cases standing your shocks more upright can make the car more responsive. It's odd.. But, it happens.
It's a new day! :)
PLUG IT IN, TURN IT ON, DRIVE!!! MAN, I LOVE ELECTRIC.
i actually think that it handles better with the shocks layed down like this.....only thing is that there isnt much tunability for the ride height as it would be if the shocks wer standing up,i think its better like this for the CoG aswell...also i think this may reduce the shock shafts bending
What's up everyone I need some help my club wants to run mini's for the winter and everyone else is getting the mini t and for some reason I want the rc18. The track will be built in a nice size basement with carpet I think and some jumps maybe, I'm looking at getting the rtr and I have a spektrum back up to my main stuff but what I need to know is everything I can do to even more have this race ready with out the motor like shocks,foams , dogbones battery packs stuff like that. Do these things use diff oil shock oil stuff like that.
So about how much is it to build one up, they may do the modded class later so that's why I'm looking to do everything but the motor. And where can I find videos of these in action.
Just start with a stock RC18 and add the DP draglink and a set of foams to start with. Everything else really is just fine tuning that you will do as time goes on. I couldn't begin to tell you how much money I have spent on these things. It's been a lot of trial and error. But the setup that I posted above is proven.
I did forget to mention above that you are going to want to find some sort of aftermarket servo saver. The stock saver is very loose and doesn't track very well.
I did the 0-ring mod to my servo saver and it's 300% better.
I also made my own draglink out of tin while I wait for the DP link and gear cover to show up
