Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-26-2006, 08:38 PM   #16
thachowman's Avatar
Originally Posted by tc4
Hi all,
i am thinking of buying a rtr mini-t and i have a few questions.
1. How many turns can the stock esc handle?
2. Is there any hop-ups i should consider buying once i get it?
3. How fast do they go out of the box?
1. Not sure of the limit but I ran an orion big block with mine and it was fine
2. Bearings and oil shocks also maybe some more tyres the losi step pins hook up good on all surfaces, 6 cell nmih pack for sure or lipo pack, also spare pinions, and servo if you run with the stock electronics.
3. out of the box they are pretty good to run indoors etc, but out side they aren't much ( with the stock 4 AA battery holder) but a 7.2 pack livens them up a fair bit , I'd say maybe 20klm/hr stock . The losi speed motor is a bit better but any more you'd want a different motor.
Personally I'd reccomend that you go the pro version straight up as they have most of the essential hop ups stock, them get a hitec HS55 or similar your own radio gear and a nice esc not necessarily a micro esc but a small one like LRP Quantum ( any of that range) or the new AI speedies, Nosram dominator or Hawk series, Futaba esc's or KO The yare all quite small and you'll be much happier with their performance, I went the RTR then upgraded it to pro specs and it cost me more than if I bought the pro in the first place.
Cheers
Chow......
_____________________________________________
Action R/C Team Schumacher Driver
Schumacher Mi4 -Mi3 - LRP - Spektrum - Ko - Action R/C
thachowman is offline   Reply With Quote
Old 06-27-2006, 11:25 AM   #17
Send a message via MSN to TAMIYAMANUK
i have just bought a mini t its all stock apart from the battery.
just woundering what hopups i will need just to keep the mini t running as it will mostly be run inside and on grass (DRY) and tarmack.
cheers ash
TAMIYAMANUK is offline   Reply With Quote
Old 06-27-2006, 06:40 PM   #18
tc4
tc4's Avatar
What sized servo will fit in the car?
Also if i wanted could i buy and aeroplane esc? would any of these work-
Schulze Slim 20be - 20 amp (30 amp Max), 6-10 cells, 9g weight including brake feature. Ideal for electrics with Speed 280-600 motors.
or
Schulze Slim 26be - 26 amp (35 amp Max), 6-10 cells, 9g weight including brake feature. Ideal for electrics with Speed 280-700 motors.
Heres the link to them if you need to see a pic. Those 2 are the ones im looking at.
http://modelflight.com.au/electric_s...ontrollers.htm
-Corally RDX PHI
-Johnson 540!
tc4 is offline   Reply With Quote
Old 06-27-2006, 07:08 PM   #19
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
cheers ash
ball bearrings for the wheels,maybe if u want to use Touring car wheels on the back get some 1/10 scale touring car axles and 2 5x8 bearings for each side and u can use any wheel with a 12mm hex,u may need to space up the axle abit tho...the stock axles are pretty dam weak and i accidently used some red threadlocker instead of blue because i couldnt find my blue stuff and i had to brake off the axle to get the wheel off lol..pretty flimsy....
the TC axles will work with the stock dogbones too.......
if u guys dont get the picture ill post up a pik...
get a 2 cell lipo or some 7.2packs...the 2 cell lipo with stock electronics will make it go around 35k's....i got a 2 cell 800 mah lipo and 18Tooth pinion with thunder tiger motor and it flys....wheelstands and all.....
the 7.2 nimh packs are tooooooo heavy if u ask me....and the lipos last way longer
ProudSavageOwnr is offline   Reply With Quote
Old 06-28-2006, 04:23 AM   #20
was thinking of switching the servo over as i have herd that they pretty crap i will be switchin the stock electics over with some better stuff as well.
and looking forward to be jumping my dog with it lol
or get a mamba and start racing for money lol
Old 06-28-2006, 04:51 PM   #21
raffaelli's Avatar
Send a message via AIM to raffaelli
I have 5 or 6 box stock
Mini-T's. My family plays with them as often as we can. We are considering building a track in the yard. We would like to keep the trucks as stock as possible.
What size track and lanes would you recommend? Space and budget are not really a concern. I was thinking 20'x40'. Suggestions or photos of your track?
www.raffaellimotorsport.com | uSucK racing
raffaelli is offline   Reply With Quote
Old 06-28-2006, 09:42 PM   #22
thachowman's Avatar
or
Only micro sized servos will fit such as the Hitec HS 55/56 etc but you can modify the chassis to fit a HS81 but it is heaps of work, I'd go a HS 56 or the JR equivalent if you chat to the guys a modelflight they'll point you in the right direction, you also need a micro servo saver to suit either the JR or Hitec they are an option part .
As for the esc you still need the motor and for the price of the plane brushlesss setups you could almost get a mamba or tekin a car specific system so your profiles and programing will suit car driving look here http://www2.towerhobbies.com/cgi-bin...&I=LXHAJ0&P=ML this would suit the mini T great with heaps of speed and run time .
Hope this helps oh and how is the JRXS treating you ? having many wins ?
Cheers
Chow......
Old 06-28-2006, 10:47 PM   #23
tc4
tc4's Avatar
Thanks for that.
Yeah the jrx-s is going awsome and yes i have had lots of wins with it.
-Corally RDX PHI
-Johnson 540!
Old 07-02-2006, 01:22 AM   #24
tc4
tc4's Avatar
Does anyone know where you can get Spy 7.2v battery packs from. They are like 3 cell but 7.2v. Heres a link to one in a car. If you scroll down you can see a pic with the body off and look at the pack. Does anyone know where i can get one of these.
http://rccaraction.com/rc/articles/minit_mad.asp
Also does anyone know where i can get a 2cell Li-Po pack to fit in the mini-t from? Do you have to use special li-po chargers to charge them?
-Corally RDX PHI
-Johnson 540!
Old 07-02-2006, 05:42 AM   #25
My minit.... Mambafied 6800kv on 6cells! 3c lipos soon!
gpm threadable shocks, gpm ti turnbuckles, gpm alloy 59T spur, dynamite alloy battery strap, dynamite alloy diff case, dynamite front steering knuckles, BRP extended body mounts, RPM front bumper, hitec 81-mg servo, Losi cvd's
since then I upgraded to a Topcad Motor plate and all around gpm road rage tires! Man these tires stick to the ground!! Hope you like it! Danny.
http://photos.hobbytalk.com/showgal...00/ppuser/31240
n3rd420 is offline   Reply With Quote
Old 07-02-2006, 07:05 PM   #26
thachowman's Avatar
Try stormerhobbies for thr Novak Spy packs and her for the lipo http://www.modelflight.com.au/flightpower.htm you need atleast a 20c discharge rate for a mini T with brushless and yes you need a dedicated lipo/lion charger, like much more CTX, team orion Advantage or druatrax ICE, Swallow chargers are also good lipo chargers. hope this helps..
Cheers
Chow......
Old 07-02-2006, 07:27 PM   #27
Man i HATE it when those gutters jump out infront of you whilst you're just mucking around..
Bent CVD, broken rear hub and many bent turnbuckles...
A_Stevens is offline   Reply With Quote
Old 07-02-2006, 09:41 PM   #28
the only thing i had to replace on my mini t are the servogears and that was sorta my fault.....i was running in fine dirt and it had built up around the servo saver and had caused it to like jam up.....hit the garden post n it broke lol....and i gotta replace my chassis too....went full speed into a fishtank lOL!....snapped in half lmao...i still run it with a snapped chassis.......i put a 1mm thick plate underneath lol.....i dont realy have to replace it.....and ive broken the front bulkhead thing that the shock tower screws into.....i fixed that up with a brace too.......and now my diff gave out and i only got 1wd LOL.....still works
may be getting a jwerks brushless system...then ill go ball diff....
the rear shafts are bulletproof...1/10 scale dragster shafts that had over 7hp going through em..i doubt ill blow those suckers
Old 07-02-2006, 09:54 PM   #29
Where're you getting your Jwerks from?
Just a tip, Get a dual disc slipper before the ball diff or you'll end up buying the ball diff again. 8000 systems without the dual disc will tear it a new one.
Old 07-02-2006, 11:53 PM   #30
Just going to mention, before you run out and pick up a Jwerks, ebay has Quark Pro Car + Hacker E30-13L 's for A$140. That's a fairly tops price for a new system, and supposedly the Quark is a very nice controller.
Forum Jump
OFFICIAL MINI LST THREAD applestuff Micro and Mini Scales 56 09-19-2008 07:39 PM
Official Kyosho Mini Inferno Thread Jerseyboy Micro and Mini Scales 18 01-24-2008 11:35 PM
the official kyosho mini inferno half 8/09 thread . MADMAN23 Electric Off-Road 2 12-27-2006 06:53 PM
OFFICIAL THREAD FOR GAS POWERED MINI CARS, TRUCKS & BUGGIES VR2L_DUDE Micro and Mini Scales 26 12-13-2006 08:39 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
