Mini-t 2.0!!!
#391
Pretty sure this is the video you saw. Tires are part # 41009. They've been out of stock everywhere for a little while I believe.
#392
My Mini T 2 shocks came yesterday, I haven't set them up yet, but they look really nice and appear to be high quality. I'll post photos and my review once I get them installed.
#393
Foams for the Mini T
#394
What are good tires for on-road use? Ordered two mini-t's
#395
okay, update on the aluminum shocks. THEY ARE POINTLESS.
They have the same horrible design as the plastic ones. Only difference I see is that the housing is aluminum rather than plastic. I paid $50 for a full set of shocks that really offer no added benefit compared to the stock plastic ones. The aluminum ones are a 1 piece design, where the caps are molded to the body. You have to fill the shocks from the bottom. Why Losi did this is not something I understand. It makes filling them really difficult and really difficult to seal w/ air bubbles removed.
Had I done this again I personally would have found a similar shock from a different brand that matched the size of the stock Losi shocks. It's my only complaint w/ this car, yet to me it is a big one.
#397
#398
yes, bottom filled on the aluminum as well. Really sucks.
Save yourself the money, the plastic ones are just as "good" in my opinion.
#400
Found it, thanks!
#403
Anyone happen to know if the differential from the 2.0 will fit the 1.0 transmission? Badly need a set of diff gears for the older transmission.
#404
I would imagine the aluminum bodies to be a little smoother/lower friction than the plastic bodies, so there maybe a subtle performance benefit there. It would really have been nice if they built the shock like a modern top-filled shock though and not like a copy of the xxx-t shocks from 2003 LOL
#405
The plastic ones are just as "good" but the aluminum ones sure look cooler!
I spent $50 for the full set of aluminum shocks, to be honest the $50 could have been spent on an upgraded esc/motor combo ...that would have provided a much better performance increase for the money.
