Go Back   R/C Tech Forums > Company/Manufacturer Forums > MaxAmps Support Forum
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-05-2009, 09:19 AM   #1
d4man's Avatar
Default What charger/plug combo for the Tx pack
I was thinking about getting this battery for my M8. It will fit because my buddy has one for his 3PK. I was wondering if my Hyperion EOS0606i DC Balance Charger will charge this battery? If my charger will work, should I get a set of Deans mounted on the the battery? Are these the settings? 3s lipo...2500 mah equals a 2.5 amp charge rate, correct?
d4man is offline   Reply With Quote
Old 10-05-2009, 09:42 AM   #2
JAM MaxAmps's Avatar
Yes your Hyperion charger will charger it you can either get a second plug or make a charger lead that has the correct plug. One option that many use is the JST mini plug as a second plug then get the other end from our plugs and wire section of the website along with a set of 4mm plugs. Yes 3S 11.1 volt pack with capacity set at 2.5 amps for 2500 mAh.
Jason
Jason
MaxAmps Marketing Manager
jason@maxamps.com
www.NitroKillers.com www.MaxAmps.com *Team Terribles Sponsor/Member* Caster Driver
JAM MaxAmps is offline   Reply With Quote
Old 10-05-2009, 09:46 AM   #3
d4man's Avatar
Thank you Jason for your quick reply
Old 10-06-2009, 03:40 PM   #4
smokinu's Avatar
Trader Rating: 23 (100%+)
looking at that pack for my 3pk i want to put a balancer on it how do i go about ordering it with that option...
T E A M T E R R I B L E S
West Coast Rep/Califronia organizer.
smokinu is offline   Reply With Quote
Old 10-06-2009, 03:58 PM   #5
We don't offer balance tap plugs on the TX'r Li-Po packs. Main reason is that the discharge rate is so very low that it doesn't pull the cells out of wack. And the 2.5 charge rate is low as well. I've got an almost 2 1/2 year old pack in my DX7 and it's still like new. No issues.
Jason
Jason
jason@maxamps.com
Old 10-07-2009, 02:12 PM   #6
smokinu's Avatar
Jason
ok thats cool
i was just asking because your website says otherwise.
"Note: This pack does not come with balancing taps. Make sure your Lipo charger is capable of charging without a balancing tap. Otherwise, request a particular balancing tap to be installed on your pack"
Old 10-07-2009, 02:16 PM   #7
Originally Posted by smokinu View Post
ok thats cool
Yeah sorry about that I forgot about that deal. Some people use chargers like the Electrifly that charges thru the balance taps. If you want you need to call the order into the shop to get the balance taps put on the pack. 1-888-654-4450.
Jason
Jason
jason@maxamps.com
Old 10-08-2009, 02:06 AM   #8
smokinu's Avatar
Jason
My triton can charge without it I'll be ordering soon thanks Jason always a big help when I purchase packs
Old 10-09-2009, 05:50 AM   #9
Sounds good and your welcome.
Jason
Jason
jason@maxamps.com
Old 10-13-2009, 09:16 AM   #10
good info...
sean2sean is offline   Reply With Quote
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
